Question about Altec Lansing Multimedia Computer Speakers
I have a set of used speakers from Altec Lansing (specific model that is says on the back is BX1120) and I'm not sure if these are plug and use, or if I need a disc, regardless I've plugged them in, and get no sound.
    President:
  • 2,030 Answers
Speaker rarely ever need a disk.
They may be amplified speakers which require power.
Posted on Nov 13, 2009
Altec Lansing BX1120 Computer Speakersrepair
You don't need theory of operation. Altec systems don't publich the schematics so your best bet would be component level work with an ESR meter, an oscilloscope, transistor tester and DMM.
Oct 18, 2017 | Audio Players & Recorders
Speakers won't work on ASUS P8Z68-V PRO/GEN3 motherboard
Speakers don't require drivers so test them elsewhere, and test your system with headphones to establish you have sound.
Some audio allow for the changing of the ports. Maybe called Smart Jack or Jack Detection. Open Audio Configuration Utility and make sure the green input is still the speaker input.
This MB has this feature with software provided.
http://www.asus.com/Motherboards/Intel_Socket_1155/P8Z68V_PRO/#specifications
Nov 01, 2012 | ASUS P8Z68-V PRO/GEN3 Desktop Motherboard...
My right speaker altec lansing vs4121 no sound only power
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps
Jul 01, 2011 | Altec Lansing VS4121 Computer Speakers
There is no sound from my speakers altec lansing model bxr1220
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 26, 2011 | Altec Lansing BXR1220 2 Speakers
My altec lansing ada885 computer speakers is making a constant buzzing sound every time I turn it on. Can anybody help me with this problem? plzzzz
hope this helps
May 20, 2011 | Altec Lansing ADA 885 Computer Speakers
Only one in the pair of altec lansing speakers is working.....the other one with volume control on it is'nt working ...what should i do ??
orbe sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Mar 07, 2011 | Altec Lansing Multimedia Computer Speakers
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
VS2521
I found that one of the pins of the plug connecting the sub-woofer was bent and the plug was not seating properly deep in to the slot. Every pin has a specific task to the sound system, it seems. I set right the bent pin with a long needle gently and re- plugged in to the woofer's slot. After that every thing works amazingly. All it requires is patience and application of mind for a while exclusively focused on the problem.
Thanks and regards
M. Narayanan
Jan 15, 2010 | Altec Lansing Audio Players & Recorders
Ive just brought my computer and it came with altec lansing serious 100 speakers im not sure how to set them up?
There should be a green color cable (3.5mm in size) coming out of one of the speakers. That cable connects to the green color port in the back of the computer.
If your still having trouble please comment back with the model of the speakers... Altec Lansing Series 100 Model ??? and brand name and model of the computer. If it's not a brand name computer but a generic PC, then the brand name and model of the motherboard.
Aug 14, 2008 | Computers & Internet
One drive for Altec Lansing Technologies Inc. 'ACS-295' dell
Hello there
What kind of help on specific device from altec you need?
be more specific
Nov 28, 2007 | Altec Lansing ACS 295 Computer Speakers
205 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
