Question about Vanguard International Infra Red - Large Infra-Red Baseboard Heater
The flame in weak and it heater will not light
  • 193 Answers
You need to replace the ODS pilot assembly.A low pilot flame will not allow sufficient heat to generate proper voltage to hold valve
Posted on Nov 14, 2009
Why would there be a weak pilot flame so my heater won't light
The orifice in the pilot light nozzle may be partially clogged.
Aug 25, 2014 | Vanguard Heating & Cooling
Jandy lite 2 pilot wont light
dirty pilot tubing or weak pilot generator
Dec 04, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
The pilot works and the flame comes on but when the flame goes out so does the pilot light
Uswually when that happens it is because the pilot is too weak... the pilot is not focused on the thermocouple properly or the thermocouple is weak...
You will need to figure out which of these things are causing your problems...
heatman101
Jan 04, 2011 | The Companion Group Kozy World Portable...
Pilot light goes out when the burners shuts off
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Dec 19, 2010 | The Companion Group Kozy World Portable...
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Aug 30, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
Oct 26, 2009 | The Companion Group Kozy World Portable...
My ventless gas heater has an uneven flame with orange tips, the flame toward the outer edge is higher than the flame in the middle, and also,when I light the heater, it doesn't just give me a piolot...
This sounds like your gas valve is weak. An orange flame has to much gas and not enough air mixture. Have you trie to ajust the air mixture. If it won't ajust then you will need to replace the valve.
I hope this helps.
Oct 24, 2008 | Heating & Cooling
Vanguard International Infra Red - Large Infra-Red Baseboard Heater Logo
81 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
