Question about Nikon Coolpix 4600 Digital Camera
Turning on the camera
When I turn on the camera it says memory card is write protected. If I put in another card it does the same thing
  • 319 Answers
Please look at the memory card closely. If there is a write protect switch, it will give you this error. Please ensure that the write protect switch on the memory card is not in the lock, or protected position.
See more information about SD cards here.
Let me know if this helps!
Brian
Posted on Jan 08, 2008
  • Brian Berndt
    Brian Berndt Jan 10, 2008
    What did you find?
robmcd27
  • 423 Answers
SOURCE: my DSE memory card says 'write protected'
Hi there, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Posted on Feb 27, 2009
SOURCE: how to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
Posted on Sep 18, 2008
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
  • 77 Answers
SOURCE: HELP
Remove the memory card and look at it, on SD cards there is a small switch on the left that you can use to lock or unlock data.
Posted on Aug 01, 2009
Turn off protected mode
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 10, 2012 | FUJIFILM FinePix JX310 14.1 MP Digital...
My screen says memory card is protected (reset switch on memory card)
Just turn off the camera and take out the memory card. Then just adjust the small tab located at the upper left side of the card to unprotect it. Then put back he card and turn on ye camera again. That's it!
Jun 27, 2011 | Cameras
Turn on camera and get card locked sign
Take the the memory card out. On the side of the card, there is a notch, it moves up and down. If you see it up, move it down or vice versa. It should unlock it. Then put it back and turn the camera on.
This notch serves as a write protect feature of the memory card. If this thing breaks, the card will remain protected and you can no longer writable.
If this fails, try inserting another card, if shows the same error, it means you camera needs repair.
Please dont forget to rate a 4 thumbs up for this solution to your free question. Good luck!
Oct 02, 2010 | Cameras
Memory card write protected
Check the side of the memory card. Some of them have a little switch that turns on/off write protection. If there is no switch, you can try to format it in the computer first, then put it in the camera and format it again.
Jul 11, 2009 | Nikon COOLPIX S51 Digital Camera
My DSE memory card says 'write protected'
Hi there, do this:
Rob
Feb 27, 2009 | Fuji FinePix A340 Digital Camera
Fujifilm FinePix Z20fd protected card??
The memory card should have a little switch on it, try it in the other position. It is a safety lock to stop it getting wiped.
Feb 13, 2009 | Fuji Finepix Z20fd Digital Camera
I get the message "Protected Card"
on your memory card is a little switch thing. if it doesnt work one way try putting the switch in the other position
Jan 30, 2009 | Fuji Cameras
What does write protect mean?
"Write Protect" means that something is locked and your device (camera) cannot "write" to it's storage area.
What type of "storage media" are you using?
For example:  the camera's internal memory, a CompactFlash card, a Memory Stick, an "xD-Picture Card" (micro, mini or regular sized), or a Secure Digital/MultiMediaCard.
[Did you put something  (a small plastic card of some sort) into a slot on the camera before or after turning it on?
Those little cards usually have a tiny button (also called a switch or lever) on them that will move back and forth to lock (write protect) or unlock it. This sounds like the memory card inside your camera is locked or "Write Protected.
To fix this simply take it out, closely examine the memory for the button- the button will be closer to the word "lock" or "protect" and all you need to do is gently slide it in the opposite direction from where it currently is. Put it back into the camera and see if it still says "Write Protect."
Let me know...
Rae
Nov 27, 2008 | GE A730 Digital Camera
Camra memory card says write protect
Same here. So just simply changing the card makes the message go away?
Jan 29, 2008 | Olympus Stylus 710 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
237 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
