Question about GE Energy Star WCVH6260F Front Load Washer
My ge front loader is not filling with water??
    Problem Solver:
  • 11 Answers
You could have bad water inlet valves or the fill sensor is bad. (some call it a pressure switch)
Posted on Nov 13, 2009
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Front Loader Washer continues to fill with water after cycle is complete
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Sep 10, 2011 | GE WSXH208A Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a GCVH6260FWW GE Front Loader. It will not
Yes you should see it - and call an electrician they can legally disconnect the "water saver" or adjust it safely
May 19, 2009 | GE WSXH208A Front Load Washer
Water fills machine but won't shutoff
ekrok, you are going to have to change the fill valve. If water is still filling when the unit is unplugged, that means the valve is stuck open. This is not a hard fix. You will have to remove the screws on the top in back. Should be three. If this is a GE you will have to remove the front header. Three screws in back of the front header. Now the top will slide off toward the back The valve is easy to get at. Get your part at a local appiance parts store or order it from repairclinic.com. Change it out and this will be a done deal, Catriver
Mar 07, 2009 | Whirlpool GHW9100L Front Load Washer
Machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
121 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
