Wont startup DV6-10002nr was acting weird for 2 days then Mon while I was on it went black and shut down then when i try to boot it just flashes front light 3 times and then stops
    Problem Solver:
  • 5 Answers
Hmmm can you move the settings to the bios setup? if you can enter in the bios setup check if your hardisk is detected. and if it is detected then it is ok. and maybe the power of your laptop has a problem. i too also encountered that problem.
Posted on Nov 13, 2009
  • 788 Answers
Try removing the battery, memory, hard drive and CMOS battery. Flip the unit over and open lid. Press and hold the power button for 15 seconds and re-install all that you removed.
Power on unit and check.
If this unit fails again or does not start up for you, get it in the HPP for warranty repairs.
1 Year with a extended 1 year for startup or dead units.
My acer desktop computer screen is black, the power says it is on but no pic, keeps cutting off, tried to back up and restore, cut off, says problem with windows and it shut off as well, HELP!
  • When the computer will not boot up, it sound like it is booting as the CPU fan is running and the lights are on. It also finds the CD ROM but it won't boot from a CD either.
  • Sometimes when you have a computer black screen on startup and the power switch light will be green and then turns to orange or amber. Everything is running.
  • Everything seems to be running but you can't see anything on the screen, not even a flashing cursor. Your black screen in Windows has occurred before the Windows logo screen:
  • 1- adapter or video card
  • 2-RAM
  • 3-and Black screen on startup with an amber flashing light
  • Not enough power getting to the motherboard.
  • A dead power supply.
  • A bent pin or shorted out USB port causing a problem.
Apr 09, 2013 | Acer AX1430-UD30P Desktop Computer With...
My LG blu ray 3-D dvd player just stopped working. all it says is boot. I unpluged it but still just says boot. It was working fine. Now it wont turn on at all just says boot, its said boot for the pa
My LG 670 also said 'boot' after a upgrade attempt and appeared stuck there. I searched LG support for a factory reset option, which is: Disconnect the LG power cable from the wall / power stripHold down the power button the front of the player for 30 secondsRe-insert the power cordTurn the player back on. Note: my player showed 'boot' again for a few minutes, then shut off. When I turned it on again, it went through the normal power up cycle, then shut itself off (weird). I turned it on again. So far, so good.
Apr 24, 2012 | LG BX580 Blu-ray 3D Player
Imac powerpc g4 will not shut down or restart properly and will not recognize external hard drive
1. Press the power key and immediately press and hold shift-option-p-r until you hear a second startup ****. (This resets the parameter RAM).
2. Press the power key and immediately press and hold command-S. The screen should go black and show a verbose listing of the boot process in white type. When it stops, you will see a flashing cursor at the end. Type the following: fsck -f, then return. This will start a check of the file system, and the fsck program will attempt to repair any errors found. Wait until the program displays the results (it can take a while if you have many files). Post your results here. If it finds errors and corrects them, your problem may be solved.
3. (Don't do this unless the file system comes up OK and you are still having problems.) With the computer off, press and hold Shift-Cntrl-Option+Power for 5 seconds, then press the power key. This should reset the power management unit.
Feb 12, 2012 | Computers & Internet
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
I was watching the TV, and heard a weird crack sound. The TV went yellow, and when I shut it down, the lights in the front flashed as if I needed a new bulb. I replaced the bulb, and it acts like it can't...
It sounds like the color wheel has failed and needs to be replaced. I don't know what brand you have but I would find a factory authorized repair center for that brand. You can usually find one by googling the manufacturers' name.
May 04, 2010 | Televison & Video
After erratic behavior ,heat and air went out
BAD BLOWER CAN SHUT ALL DOWN. IF BLOWER WAS LOUD BEFORE SHUT DOWN THAN IT MAY BE TIME TO REPLACE. DOES BLOWER COME ON WHEN TSTAT IS SET TO FAN ON
Apr 20, 2010 | Heating & Cooling
MY LAPTOP WENT BLACK AFTER I SPILLED SOMETHING ON
Its better to show it to technician bcz it seems the motherboard inside lost bios flash and its unable to detect old settings so that everytime it reboots checks bios and then reboots again to flash it. Better show it to a local technician. One other way is to try booting it in safe mode and then check if it works.
Oct 29, 2009 | Compaq Presario Notebook
Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
May 10, 2009 | ASUS G1 Notebook
GA-8IPE1000 Pro
Hi, Does it start to boot from windows and then shut off or is it before windows? Try removing the HDD and see if it will still shut down. If it does not shut then with the HDD removed, then the OS on the HDD is corrupted. Thanks, Mike
Nov 02, 2008 | Intel Motherboard
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
Aug 14, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
