Question about Makita 9901 3 inch x 21 inch Belt Sander with Dust Collection, 1246 SFPM, 6.7 Amps
Makita 9901--How to remove and replace motor bearings
Makita 9901--I want to replace the motor bearings (parts 39 and 43) and it appears the bearings are pressed onto the shaft and should be removed with the right size gear puller (is that right?). the pullers I have are too large to getunder the bearings to pull them off. Is there any way I can avoid having to buy a small bearing puller just for this one job? Also, what do I do with the rubber pins (parts 44 and 45) when I put the new bearings onto the shaft ( I don't know where they go but in the parts diagram it looks like they are installed with the bearings. Finally, what can I do to press the bearings back onto the shaft--a vise, a C clamp, a bar clamp, some other method? Thanks, Frank
  • Zampano Nov 16, 2009
    Guru/Rowdy:
    Thanks for the advice--I don't have a bearing splitter but I think that will have to be the solution for one of the bearings which is very close to the next piece (cooling fan) on the shaft -- a puller would need knife-thin edges to work. (I had enough room to pull the other bearing with a large puller I had with my car tools).
    Thanks again,
    Frank
  • 2,176 Answers
Do you have a bearing splitter? If so I have used one and then gently tapped the end of the shaft to remove the bearing. The rubber pins fit into holes next to the bearing bore in the housing. You can use a vise and a soft hammer to tap the bearings on. Put the bearing on the vise and tap the opposite end of the shaft. You are on the right track for all these methods.
Posted on Nov 15, 2009
  • David Ford
    David Ford Nov 17, 2009
    I have also crushed the bearing in a vise breaking the outer race and then grabbing the inner one with vise grips and tapping on the shaft with a dead blow hammer to remove.
My Makita DSS610 18v cordless circular saw stopped working mid cut. I changed the battery to another, fully charged, one but still nothing. Tried again next day, with both batteries, still nothing.
Hello Derek, it seems that your motor or motor brushes have failed please contact the manufacture about replacing the motor brushes.
Sep 15, 2016 | Makita Saws
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
How to replace bearing on a red makita buffer
Too much work for the money, buy a new one. If the bearings are shot, you got some hours on it..motor brushes are next and Probly soon.
May 15, 2016 | Makita Tools & Hardware - Others
How do i remove the Base?
Makita BO4900V Parts Breakdown
Beginning with pos 6 4 screws and remove pos 1 on top 3and4 both carbon brushes with holders . now you can split the armature with base from the motor housing .thats the only thing need for it.
so you can do the job . by replace the armature look for the bearing fits well in the housing again and replace the brush holders etcetera
Oct 28, 2015 | Makita BO4900V Half Sheet Finishing Sander
Saw stopped working. changed brushes. still not working.just dead.blade turns ok.not even a click
These are notorious for burning out armatures.
The replacement process is pretty involved, I would not attempt unless you are comfortable.
Remove the brushes
Remove the 3 Screws hold the motor assy to the saw
Remove the screws holding the motor housing together.
Separate the housing and you should be able to see right away if the armature is burnt (many times the windings actually blow apart)
Often when the armature burns out it also melts the brush holder assy - I would recommend replacing it as well.
If the armature appears fine then I would lean toward the switch. Makita BSS611 18V LXT Lithium Ion 6 1 2 Circular Saw Parts
Mar 12, 2015 | Makita Bss611 18v Lithion 612" Circular...
Bad bearing on makita ga4530. How do I get to the upper bearing?
You have to take the gear housing apart, remove the hex-nut and spiral bevel gear on the end of the armature so you can pull the armature out of the bearing. Then remove the retaining ring, o-ring and bad bearing for replacement.
Oct 10, 2013 | Makita GA4530 4 1/2" Grinder
Kenmore 9901 dryer - heating element burned, fuses are OK. How to replace the heating element?
FIRST-DISCONNECT THE ELECTRIC SUPPLY.
Go in through the back. Disconnect the wires going to the heater chamber. Remove the 3 or 4 screws holding the chamber in place. Remove the chamber. Remove the 4 screws holding the element assembly in place. Replace the element and put everything back into place.
Dec 19, 2012 | Kenmore Dryers
How to remove armature in makita 5806B
Removed the three screws to release the motor housing from the blade housing. If the the armature stays in the motor case then try tapping the edge of the open end of the housing with a soft mallet. If it still won't move hole the end of the armature in a vice using SOFT JAWS and then tap the edge of the housing to remove the motor case.
It might be that the rear bearing has siezed in the housing.
Jun 17, 2012 | Makita Saws
My makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Oct 29, 2010 | Makita 9404 4'' x 24'' Belt Sander
Makita 9901 3 inch x 21 inch Belt Sander with Dust Collection, 1246 SFPM, 6.7 Amps Logo
623 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
