Question about IBM ThinkPad (22P9163OB) (22P9163-OB) CD-RW/DVD-ROM (Combo) Burner
Drive does not recognize inserted disks
Thinkpad T61p with Vista Ultimate will most often not recognize a CD, usually prompts to format the blank disk - only it is not a blank disk it is a valid data CD. Drive is a DVD-R ATA and I am using the standard Windows driver dated 6/21/06 version 6.0.6000.16386. If I run the drive troubleshooter from Lenovo from http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4Y67L9 it will magically start working again. Even rebooting will not get it to work so if I don't have internet access to get to the troubleshooter I am out of luck
  • Anonymous Jan 09, 2008
    Hey I Have The Same ProB
    I Use ASUS DVD RAM LIGHTSCRIBE And run vista ultimate
    The Drive Or OS Does Not Read Disc
    It Says Prepare Blank Disc
    This Is Really A Big ProBLEM IM SURE THAT THERE IS NOTHIN WRONG WITH OUR DRIVES .............................................................................................................
    Problem Solver:
  • 14 Answers
You Have Got to Go to www.afreedll.com or www.dll-files.com
And Search For AutorunGUI.dll And CDROM.SYS
Download And Copy The AutorunGUI to Windows Drive System 32 Folder
And The Other to System32 Drivers Folder
HEY THIS DID NOT WORK TOTALLY FOR ME BUT AT LEAST NOW WHEN I LOG OFF AND SWITCH BACK IT READS
..........Still Need Help.................................................
Posted on Jan 09, 2008
  • Anonymous Jan 10, 2008
    Got The Best Solution:
    My PC Was Having Many Worms Trojans
    Thats Why It Did Not Read
    Download a Free Worm Cleaner From www.avast.com And Install and Clean Your Computer and Restart
    This Worked Totally For Me If this Doesnt Work For U BackUp Vista and Reinstall A Clean Vista.
    But Im Sure My 1st Solution Will Work 100% sureabout it
    www.avast.com and download a free worm cleaner
    This Works 100%
    ,Good Day
6ya staff
SOURCE:
My hp 630 cannot read a CD/DVD, when inserting a Disk it doesn't recognize it so what seem to be the problem because the Cd Rom tells me that it is OK but doesn't recognize a CD?
It is possible the lens is dusty and may need a cleaner inserted or if it is a blank disc you are trying to burn try another brand some cheaper brands do not have capability.
Sep 26, 2013 | Microsoft Windows Vista Ultimate Edition
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
I purchased a Sharper Image 3.2Digital Photo Viewer. I inserted the CD into my drive as instructed, but the message I am getting is as though the disc was blank. It is not allowing me to install the...
Sadly FIXYA can not FIX this . CONTACT SHARPER IMAGE .Installation disks do not require formatting ever .it is possible that it is not compatible with VISTA
Nov 12, 2017 | Sharper Image Audio Players & Recorders
Why won't CD/DVD RW drive won't recognize DVD disk?
Make sure you have the most current driver installed for that model. Go to IBM website and download, install. Once installed, try reading the disk again. That usually solves the problem.
And - all CD/DVD drives don't recognize all CD/DVD's - lots of different formats. Check the documentation for that drive to see which formats it can read.
--Crazy PC Lady
Dec 24, 2010 | IBM ThinkPad T30 2366 Notebook
How to reformat my vista computer?
insert windows cd ,, shutdown,,,,,,start,,,,, boot from cd,,,,,, select disk drive,,
Jul 26, 2010 | Microsoft Windows Vista Ultimate Edition
Doesn't recognize cd or dvd disk when inserted in
acer 4520 doesn't recognize cd or dvd when inserted in disk drive
Feb 06, 2010 | Computers & Internet
My DVD drive does not seem to recognize "space" on blank DVDs. I inserted a blank DVD and it kept telling me that it had 0 byte on my DVD when in fact it had 4.7 GB.
Normally a DVD blank or has data stored on it will not show unused disk capacity. If will show the disk capacite of the space it has used.
The read/write DVD disks will show the capacities used and unused after the disk has been formatted and data copied on these DVD disks.
Sep 14, 2009 | Lenovo ThinkPad T61 Notebook
DVD CD-R drive does not recognize a blank CD on toshiba sattelite
Try this before you enter disk.
  1. setup software or files to transfer when prompted to enter CDR, then place in drive.
  2. Or open my computer, select cd drive right click select, format disk. When prompt comes up for disk insert CDR.
Some systems have trouble with other manufactured formatted disk.
Mar 06, 2009 | Toshiba Computers & Internet
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Open Questions:
See all IBM ThinkPad (22P9163OB) (22P9163-OB) Questions
IBM ThinkPad (22P9163OB) (22P9163-OB) CD-RW/DVD-ROM (Combo) Burner Logo
423 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
