Question about GE Refrigerators
New french door GE fridge that won't stay cold
New french door GE fridge and freezer that won't stay cold. The lights are on and the control panel is lit but the fridge and the freezer are warm. There is no sound from the unit that would make you think it even running.
  • GE Master
  • 1,606 Answers
If " new " is less than 1 year , you will need to call GE factory service , for a warranty repair . If any one else works on it , this will void your complete warranty , and they will charge you for a service call + parts + labor .
Posted on Nov 13, 2009
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
The fridge isnt cold but freezer is cold
You might need to have the oxygen added or the compressor replaced. Try switching the mains off for a day and leave all the doors open. This will help the ice build up between the freezer and fridge defrost to allow the cold from the freezer cool the fridge. This a temporary solution and it might give you a month before it builds up again.
Mine had the oxygen added and the compressor changed and it was good as new after that.
Sep 04, 2012 | GE PDS22LBN Bottom Freezer French Door...
My GE Fridge is not getting cold
if the freezer is still o.k. then replace the control board located in the lower rear of the unit
Dec 24, 2009 | General Electric Profile PFSF5PJX Bottom...
Refigerator is freezing food
Hi, this problem is going to be with the running thermostat. It has gone bad and stays open which in turn will keep the compressor running continually. It can normally be located in the control panel inside the fridge. Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Lights are on controls on not cooling
hi thanks for the question Your fridge is stuck in defrost cycle replace defrost timer. THanks for the Question The appliance doc
Sep 12, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Controls not working in GE Bottom w/french doors.
I have the exact same problem with mine.  I was away for 3 months, left it running. Came back and no display.  Unplugged it & restarted it and it worked for a little while and went out again.
         Did you ever get an answer?             I'm wondering about corrosion on the door switch from lack of use, as the display is only supposed to be on when a door is open.  Yours may have been a loose connector from moving it???
Aug 31, 2007 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
