Question about Lexmark X3550 All-In-One Printer
I unpluged my usb cable to the lexmark x3550 printer now it wont work , i though it would reload without the cd . but now i cant find it won't i donot have the cd to reload
  • Lexmark Master
  • 6,487 Answers
You can download the printer software from this link so you can reinstall the printer back.....
http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_X3550&segment=DOWNLOAD&userlocale=EN_US#2
Posted on Nov 13, 2009
Cant find my cd to install my lexmark x3550 can u tell me what to do
open google home page search driver magician
insatl update
all drivers
serch driver version size relaze dete
Oct 30, 2010 | Lexmark X3550 All-In-One Printer
Until a few days ago my Model X3550 operated perfectly, now the unit will not respond to print command, although it will still copy and scan and perform all other functions. Simply will not print, get...
unplug printer. uninstall the printer drivers. restart computer. when desktop comes up, plug in USB for printer. Windows should recognize the printer. If not, try a different USB cable.
Feb 04, 2010 | Lexmark X3550 All-In-One Printer
The connection to the computer is not working correctly. We have reconnected everything, and it is still not working
try another usb cable to connect the printer to the computer.. if the same check first the usb of your computer if it is okay..now check the usb port of printer. connect to another computer if the same problem cant connect it means the printer usb has deffect need to fix that
Sep 14, 2009 | Lexmark X3550 All-In-One Printer
CANT INSTALL NO Ubs CABLE AND THE DISK IS HAVING A PROBLEM WORKING
Most printers do not come with data cables - either USB or Parallel. You have to get one for yourself ok. About installation, for most USB printers, you don't need to attach to the pc before copying the drivers to hard disk. If you had done that already, you put back the driver cd into the drive tray and then uninstall. You'll have to connect the printer via USB cable only when prompted and allow to detect the printer and complete the installation process by itself ok. Just select the recommended installation type and it will run automatically. Good luck
Jun 03, 2009 | Lexmark X2600 InkJet Printer
Lost cd to printer Lexmark x3550 help me find one
Hi though you dont have the CD here is the driver to download find the link below its the driver for your Lexmarkx3550 this driver is compatible for both XP and Vista
http://www.downloaddelivery.com/downloads/cpd/cjb3500-4500en.exe this link is from lexmark website ..
thats the content of you CD Driver and Applications
Jan 28, 2009 | Lexmark X3550 All-In-One Printer
Help with fax please
Please click the below mentioned link to download the Fax Solutions software. But, it is supported for upto XP.
Fax Solutions Download
Thank you
Dec 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x3550 printer
The issue which u r facing is" Communication issue"
Make sure u have installed the lexmark printer software...or else download it from the lexmark website(lexmark.com)..choose the s\w for ur operation system( Xp or vista(32bit or 64bit))...
If s\w is installed...
Check the USB cable..try different port...
Clear all the docs in the printer folder...
Remove the power adaptor and replung..restart computer..
When u unplug and replung the usb cable doesn ur computer give a pop up "found New hardware" ?
U can also try...
Uninstalling the s\w....disconnect the USB cable..reinstal the s\w and connect the cable when it prompts to...
Jun 09, 2008 | Lexmark All-in-One Printer with PictBridge
XP refuses to restart after installing printer
It’s not uncommon for software to mess up during installation.
Or even have a bad CD. (Please make sure you're windows XP software is up to date, run windows update service).
Since you are able to get into windows, open control panel, open add/remove programs & uninstall the Lexmark printer software. After uninstall restart the PC. Power on the printer before windows loads. See if windows runs with the printer connected & powered on. Less Its driver software. Windows should see the printer & ask for the software. (If so, it may be corrupted software). Go to Lexmark for driver software & download it.
http://search.lexmark.com/printer/US/en/1410000
Try reinstalling using the online driver software for the X3550 printer. If it still stops you're windows, I would suggest replacing the USB cable. If replacing the cable does not help & windows does not load, there could be something wrong with the printer.
If this is a new printer you should contact Lexmark.
http://support.lexmark.com/static/229-1-0-582.html
Lexmark will suggest all of the above. You'll be three steps ahead of support. Lastly, I have come across an issue from time to time installing printers software into Windows XP systems.
(It matters not the printer model). Windows was missing basic printer files needed to operate any given printer. The fix for those systems was a complete fresh install of windows. Its suggested to never use a copied windows CD. It matters.
Good Luck electrics!
If I can help you further, feel free to post.
There is rarely 1 way to fix every thing.
Mike
May 30, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X3550 All-In-One Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
