Question about HP PhotoSmart 1215 InkJet Printer
HP error code 0xc18a0001 on my HP C7280 all in one printer. I am using non HP inks and have just filled all of them up and reset the printer chips. I have been trying to fix this problem for 6 months now with no luck. HELP!
    President:
  • 2,030 Answers
That is an ink system failure code.
This happens alot using refillable and reset cartridges.
Try this..
1) unplug power
2) hold the power button and reinsert power cord
3) let the printer boot up
4) try it...if it works fixed.
Also HP has some special firmware upgrades available if you get hold of them by email or chat.
Also...don't tell them your using Non-HP ink, or they will drop your call like a hot potatoe.
You might try some HP inks and see if the cartridge change to HP works.
Posted on Nov 13, 2009
I want to use non HP Ink ! but this happened !!!
Send a test print to it from the printer properties. If you did not have any issues before you re-charged the printer cartridge, try another cartridge.
Oct 10, 2012 | HP Photosmart C7280 Laser Printer
I'm getting an error 0xc18a0001 on my hp 3210 printer. What does it mean? How do i fix it?
That code indicates the the printer has the "Ink System Failure" error. This is usually reset-able. That error is normally caused by air in the ink cartridge system. To clear the error you will need to do a purge. We have a free complete guide to perform the purge at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Sep 15, 2010 | HP Photosmart 3210 All-In-One InkJet...
Error code U140 check ink because I used a non-OEM cartidge
You need to buy the ink with the new chip installed, or buy a resetter. The only way to print now is with a new cartridge either Canon, or with a new chip.
Oct 01, 2009 | Canon PIXMA MX310 All-In-One Printer
I have just installed a non hp colour cartridge into my f2180 series printer and am getting a message saying error with print cartridge and a red warning light on printer i know the cartridge is the right...
You are not alone all of a sudden lots of people are having problems with non original cartridges for many makes of printer
If you just bought them then you should take it back and exchange it or if you filled them yourself read on below.
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Cheaper replacement cartridges are quite prone to this chip failing completely rendering even a new cartridge effectively useless
Re-filling them will have no effect
Should you fill your own then if you are lucky you should be able to find either a chip resetter around on the internet or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well
Sep 01, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP PhotoSmart 1215 InkJet Printer Logo
711 people viewed this question
Seeker5211
Seeker5211
