Question about HP Inkjet 2600 Printer
What does E C mean? I put in a brand new cartridge using 15A refillable and I understand it doesn't read a refillable cartridge, but it's not letting me print anything out. Please help!
    President:
  • 2,030 Answers
It wont....the printer does not know that there is ink in the cartridge, you must rest the chip, or use a new cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Nov 13, 2009
I PUT A NEW BLACK CARTRIDGE IN AND I STILL GET MESSAGE THAT BLACK INK IS LOW
My first thought was, "I'll bet she put in a refilled cartridge." I understand that in some printers, unless you use a brand-new name-brand ink cartridge, this will happen.. I don't know if or how this can be remedied and still use this cartridge if it is, in fact, a refill. Also, there IS such a thing as getting an ink cartridge that really IS NOT full...
Nov 14, 2013 | Lexmark X2500 All-In-One Printer
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
Every time i turn my printer on it flashes E, 5... and the alarm button is lit. i installed brand new 40 black and 41 color canon ink cartridges, and the error still isn't fixed
r u sure new cartridge is not refilled one?
E5 error means cartridges are not readable.
When you refill your canon cartridge, especially for color one, it happens. (after 4~5 times of refills)
So you have to replace the cartridge with brand new one.
(for your additional reference, it doesn't happen to black cartridge)
So at least you can refill black...
If you would like to save money, try nozzle injection refill kit by ROADINK.
And will see how easy ink refill can be done.">
Apr 26, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Printer continually says put in cartridge even though I have (twice). I have checked over and over that the cartridge is firmly installed. Is there a sensor somewhere which needs cleaning or resetting?
Did you used refilled cartridge?
Sometimes for Canon printer, when u used refilled cartridges, they are not readable.
It's called E5 error.
In this case, you need to replace the cartridge with new one.
Apr 19, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I have a PIXMA MP 110 CANON and when i go to print it says CARTRIDGE IS JAMMED PRESS OK. The computer says it is a ERROR 5100 problem and press OK AND IT SHOULD WORK .but it doesn,t. The cartridges are...
You are facing e5 error which cannot be solved.
For Canon printer, if you refill about 4~5 times, especially color, the printer does not read that particular cartridge.
Well for solution? You need to replace the cartridge with new one.
Just blame Canon....
At least you can easily save $100 for color cartridge (facing e5 error after 4~5 times of refill)
Apr 19, 2011 | Office Equipment & Supplies
Will not let me use a refilled cardridge
You have to buy the 14A and 15A cartridges from the Lexmark site. These are refillable, though you'll have to search around for instructions - printer companies are legally required to make refillable cartridges available, but they're not required to make it easy.
Jan 31, 2011 | Lexmark Z2300 InkJet Printer
I have put an "compatible toner cartridge in my Samsung CLX-2160N
By using refill cartridges there is no easy way to reset your printer to except it. The chip located on the cartridge is letting the printer know that the cartridge is emtpy. The solution is to buy a brand new cartridge and this will clear the message for you.
Jun 04, 2010 | Samsung CLX-2160N All-In-One Printer
Refilled cartridges
the pixma range need to have the chips reset or refilled before they become empty.
Put in a genuine cartridge and it should work. Buy a set of cartridges with dummy chips that allow the printer to use refilled cartridges.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Refilled my lexmark cartridges but still dont work
14 and 15 won't work after refill. You can only refill 14A and 15A.
But even when you refill those, the printer will keep telling you they are empty, which is normal, neither the printer nor the computer can know that you have refilled your cartridges. The devices see cartridges by their serial number, so it resets the counter only when you pop in a new cartridge. They are ways to bypass that by resetting the ink level: use clear tape over the left hand row of sensors on the front of the cartridge and re-insert it. The ink now shows with question mark but reads as full and prints fine. You actually "fool" the printer into thinking you have put a different cartridge. This works with some printers, so I am not 100% sure it will work with yours.
Oct 23, 2009 | Lexmark X2690 All-In-One InkJet Printer
Refilled lexmark #4 cartridge but printer still says it is empty,
Hello sir; I don't understand "refilled " means in here, is that means refurbish, if answer is yes , try not to use it, please use "OEM". generic one caused a lot problem.
Aug 28, 2009 | Lexmark X2690 All-In-One InkJet Printer
HP Inkjet 2600 Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
