Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Screen says "no signal" - Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
  • 11,896 Answers
Check settings to make sure it is set to air or CATV depending on if you are using converter box or cable.
Posted on Nov 13, 2009
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Feb 26, 2015 | Televison & Video
Failed signal
Yes, check the cable as your tv's tuner does not receiving signal. The BLUE SCREEN on most of this brand means you have no signal from an outdoor signal or so. Thanks for using Fixya.
Apr 03, 2014 | Sharp 32SC26B 32" TV
Only has grey screen
Hi a grey screen would tell me that your screen is not getting a signal from your signal board. The t-con board is what transfers the signal so I would suspect that is were the problem is.
You can get parts at www.interliquidparts.com
Dec 08, 2011 | Magnavox 32MF339B 32 in. TV
Vizio TV with Blue Screen says, "Aucun Signal!"
Guys aucun signal just means no signal in french
Mar 01, 2011 | Vizio L37 Television
Sanyo just says no signal Screen is blaack except for NO SIGNAL moving around all over the screen
This happens when there is no signal.
For instance, if you have the screen set for VGA input, and either the computer is off, not connected, or in screen saver mode.
Check to see what input is selected, and more importantly, if there is a signal at that input!
Feb 24, 2011 | Sanyo Televison & Video
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
TEAC LCD191SD WIDE SCREEN LCD TV WHY NO SIGNAL
U have a signal word bound around or said no signal in ur LCD Screen?Than it ur colax cable not getting signal comming in.Try reset ur cable or satalite box by turning it off/on.IF the LCD screen totally black,try unplug,replug might get picture back.Not than must replaced the main video backlight board it dead must be replaced.
Oct 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
