Question about Polaroid CTA-01234S Digital Camera
Camera turns on then shuts down 5 seconds later
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 13, 2009
Reset to factory settings
This is supposed to work:
http://www.ayton.id.au/gary/photo/photo_43rds_firm.htm
1. Select P on the mode dial.
2. Open the card door and turn on the camera.
3. Hold down the Menu and the OK buttons at the same time for 5 seconds.
4. Olympus E-xxx is displayed.
5. Release and again hold down the Menu and the OK buttons at the same time for another 5 seconds.
6. Reset has been done is displayed
7. Press the OK button.
8. Shut the camera off
Jan 31, 2014 | Olympus EVOLT E-410 Digital Camera
Hard reset Olympus E-520
4. Olympus E-520 is displayed.
Nov 22, 2013 | Olympus E-520 Digital Camera
It says improper shut down then freezes up and turns itself off
First make sure your PS3 is powered off and unplugged.
1. Plug your PS3 in.
2. Now hold you power button on the ps3 down, you will hear one beep, followed by another 5 seconds later, and a third one 5 seconds after that. After that the PS3 power light will turn red. You can now let go of the button.
3. Hold your power button down again, you will hear one beap, followed by another beep 5 seconds later, and then you will hear a double beep 5 seconds after that. After you hear the double beep, let go of the power button.
4. Now some words will come up on the screen saying to connect your controller.
5. You must connect your USB cord to your ps3 and connect the other end to your controller.
6. A selection menu will now appear.
7. Select the option "3. Restore File System" and press X.
8. Now follow the on screen dialog and once the restoration has completed your PS3 will be back to normal.
Please note: Following this guide will leave your Game Data and Save Files intact, you do not need to worry about this process deleting your Save Files or any other data. Your ps3 will be just like it was before it messed up.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
My batteries went dead and camera shut off. Now I
if the camera wont turn on remove the memory card and make sure your pictures are transfered. Try using regular disposable batteries. Also when trying to turn it on try holding down the power button for 5 seconds. If it still doesnt turn on coud be a broken switch connection.
May 14, 2010 | Canon PowerShot A540 Digital Camera
How do I reset my camera to its factory settings? all my pictures are blue.
Go into the camera setting and find "reset to default" and select yes.
Make sure you have good batteries too.
Dec 22, 2009 | Olympus EVOLT E-500 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Powershot SD1000 automatically shuts down in Camera mode
In any mode that the camera will stay on, press the "Menu" button and navigate to the RESET option and try to reset the camera. See if this will get the camera to function properly.
Jun 11, 2009 | Canon PowerShot SD1000 Digital Camera
Power down
Windows does not shut down. Additional information and causes that may cause Windows 95 or Windows 98 to freeze, hang or lockup when attempting to shut down the computer.
How to restart or shutdown the computer in DOS. If you are currently in DOS and need to turn off the computer press the power button. Note: some newer computers may not allow the computer to be shut down ...
Installing a pc computer power supply Write down important information from the top or bottom of the power supply such as the Model Number, Serial Number and specifications (such as voltage...).
Basic floppy disk drive troubleshooting Power down, unplug, and open computer, being aware of ESD and its potential dangers. Verify that the floppy connection is connected to the motherboard FDD .
Good Luck, Read and follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | Intel Motherboard
Polaroid CTA-01234S Digital Camera Logo
44 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
