Question about Frigidaire Dryers
HELP!! MY DRYER HAS GONE MAD!!
MY DRYER LEQ2152ES0 FRIGIDAIRE KEEPS ACTING UP. IT JUST FLASHES 00 IN THE DISPLAY AND WON'T DO ANYTHING ELSE BUT BEEP. I FINALLY FIGURED OUT THAT IF I UNPLUG IT FOR ABOUT AN HOUR OR 2 IT WILL SOMEHOW RESET ITSELF AND WORK AGAIN FOR AWHILE. I WOULD APPRECIATE ANY HELP THAT YOU COULD GIVE. THANKS, VICTORIA.
catriver
  • 878 Answers
SOURCE: Dryer turns itself on & beeps, then off again
aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Posted on Jul 16, 2007
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
SOURCE: Frigidaire Affinity Front Load Electric Dryer
E68 indicates one of the panel buttons is stuck.
Posted on May 16, 2008
SOURCE: My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Posted on Mar 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Frigidaire FEQ1442ESO Dryer
Unplug it.
Remove the 2 screws on the back side to get the top off.
Slide the top off and take the 2 control panel screws off lift up the control panel and get he tech sheet out. Consult it to find out about them beeps. Use this LINK to access service videos for your machine.
Posted on Sep 30, 2010
Frigidaire front loading dryer model LEQ2152ES0 I am looking to purchase a used one, the owner has all paperwork and such, says the drum does not turn, sounds like it trys to but does not. he thinks i
Hey friend, thanks for the post!
If the drum is not turning on a Frigidaire dryer it could be a potential problem with the belt, motor, or control panel. The best thing to have done would be to have a professional come out and properly diagnose the appliance. Hopefully this is helpful. -Matt
Sep 23, 2014 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Why does my frigidaire dryer beep while drying?
How often does it beep and does it flash any error codes at all?
Aug 14, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have a frigidaire LEQ2152ES0 Front Loading Dryer. The machine has started to squeek rather loudly. I've noticed a
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Thank You for using fixya
Mar 14, 2012 | Frigidaire GLTF1670A Front Load Washer
How does this thing work?
Install the software on your computer. Put a battery in the camera. Push and hold the button to turn it on (display shows 00) Take some pictures - the camera makes a tiny beep, the led on the front flashes, and the count goes up by one. Push and hold delete to remove the last picture (count goes down) hold longer to delete them all (goes to 00). When you've collected some pictures, rush to your computer to download them with the USB cable before the battery runs out; when that happens the pictures are all gone (there's no flash memory in this). Holds about 40 pictures depending on the amount of detail in them.
Feb 03, 2011 | Disney Pix Click Digital Camera
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
How to to put the belt back on. Frigidaire LEQ2152ES0
I will be more then happy to help you but I need the model n serial # to better assist you.
thank you for trust fixya I will be waiting for your e-mail
May 13, 2009 | Frigidaire Dryers
Model LEQ2152ES0
check the drive belt is on the pulleys
Jul 08, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
