Question about Kirby G4 Bagged Upright Vacuum
My Kirby G4 won't turn on. Everything is engaged as I normally do it, nothing is wrong with my power outlet, changed my hepa bag to a brand new one...
  • 36 Answers
It could be a few different things. First make sure the emptor tank on the side of the unit is pushed all the way closest to the unit. ck to see if light comes on (that will tell you if you have power to the unit.) if so It is an internal problem. Or it might be, what is called the power foot switch. It's kinda of like the brain for the kirby there are 3 saftey switches built into it. they must all be working at the same time for the unit to power. If need be take it to a vacuum repair shop one with free estimates. this way they can diog. the problem and give you a repair cost, if need be. Hope this helps.
Posted on Nov 14, 2009
Kirby g4 power will not ingage
There could be a few reasons. Try a different power outlet and check the cord and belt. Next there are two safety switches on the Kirby that need to be engaged for the vacuum to start. One is on the mini-emptor to make sure an outer bag is engaged, the second is on the front nozzle to make sure the nozzle or hose is attached. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-755-6586
Jun 06, 2014 | Kirby G4 Bagged Upright Vacuum
Kirby g4 stoped working
cable has shorted out internally, will need new cable
Nov 18, 2012 | Kirby G4 Bagged Upright Vacuum
I have a G4 has been working wonderfully well, after last bag change, experiencing very low suction. Thanks in advance for your help.
The most likely reason for lack of suction is that the housing at the bottom of the bag is plugged. Firmly grip the housing and turn it clockwise to remove, and check for debris. The bag assembly will re-install more easily if you first wet the rubber gasket on the outlet. Be sure the bag is fully in place, or the motor will not run. If this does not solve the problem, it could be a bad belt, or an incorrectly installed brushroll. The ends of the brush are marked 1, 2, and 3 with notches in the plastic. In residential use setting # 1 is normally used. BE SURE both ends of the brushroll are on the same setting.
Jan 22, 2011 | Kirby G4 Bagged Upright Vacuum
How to
Hi redd79!
All you need to do is to lube up the hole where the bag goes on with either hand lotion or dishwashing liquid. Put the bag on and twist it up against the side of the kirby until it engages copmpletely. If this doesn't work, you may have a bad switch.
Just in case...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope I helped!
Marci
Aug 15, 2008 | Kirby G4 Bagged Upright Vacuum
My kirby has no suction
Even if you have a new belt, do everything this guide tells you to do. The seller may have the power nozzle assembled improperly. If the brushroll is in wrong or the base plate is not on correctly, it may cause these symptoms.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Nov 10, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G4 will not start
Check the mains socket with something else.
Oct 06, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
990 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
