Question about Acer Computers & Internet
Componenet failure Acer aspire 5920 I do not know if its a diode or capacitor. Anyway when I go to power on I get nothing. My power adapter light goes dim. Does anybody have any idea on how to identify the component and its value ?
  • sshearer09 Mar 18, 2010
    Ken Thank you so much for your help. Sorry this took so long to comment. Your solution worked very well ! thanks again.
  • 113 Answers
Start up circuit problem, double check the output voltage on the adapter should be between 16vdc -20vdc, if ok connect a load to it example dc bulb/led or the battery of the laptop, if it remains on the adapter is ok, next check the laptop battery, remove it from the laptop and using a meter check the voltage and polarity.monitor the voltage to see if it is falling or holding,it should be holding, if all is well the next step is to check the voltage at the switch, this requires you to take apart the laptop to trace/test the voltage form the input to the battery to the mainboard to the switch and back to the mainboard. if the voltage is not present on the main board you will have to check the components to see which one is defective,if a protection diode it will be a very small component (smd) usually black in color and located close to the input connector.you will have to replace it,which will require some special tools and a lot of steady nerves.if a capacitor it will be brownish in color (smd)Surface Mounted Device.
Hope this helps
Ken.
Posted on Nov 16, 2009
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Looking for an electrical schematic
Well I am going to need to know at least what kind of monitor you have here. Most likely you will need to contact the monitor manufacturer, or the power supply manufacturer if it is labeled. These schematics are controlled by the manufacturer, but can in some cases be released to the end user.
Thanks
Tim
Posted on Sep 26, 2010
My Asus Laptop won't turn back on, there is a chemical smell, and my adaptor green light brinks
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the Acer Aspire 5920 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 04, 2013 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not power on. Power Cord, Charger, Adapter and Battery work fine. Adapter lights up green, no power light on computer keyboard or On/Off switch. CPU Fan is not working. Is there a...
There is a cmos/ rtc battery but that would have nothing to do with powering on your laptop. Most likely there is an issue in the circuit at the DC power jack. If the connection seems loose, or moving the plug at the point where it connects to the computer gives a glimmer of power then it is the jack. The DC jack is usually soldered to the motherboard and requires some knowledge to repair. If the jack is okay then there is a problem further up in the power circuit on the motherboard which means trouble.
This is what you power jack looks like and yours is not soldered, but has a 4 pin connector that plugs in to the motherboard. Much easier to replace than a soldered connection. Click HERE to see it.
P.S. Just because there is a green light on the adapter it doesn't mean power is being distributed to the connector tip. You may want to try a different adapter before spending money to have it diagnosed.
Apr 18, 2011 | Acer Aspire 5920-6727 Notebook
My acer laptop 5920 just went off and now won't
Obiviously It is the problem of the connector of the power adapter.
Apr 23, 2010 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
clb199@yahoo.com
pls rate me 4 stars
Nov 27, 2009 | Acer Aspire 5920-6727 Notebook
My Acer 5920 Laptop is about a yr old. It is not switching on. The power light blinks for about 5 secoonds and then nothing happens. Please let me know if anybody has a solution to this.
Try removeing the battery, memory and Hard drive. Press and hold the power button for 30 seconds.
Re-install and reseat memory Harddrive and battery.
Try powering up the unit without the battery and any external devices.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Aug 23, 2009 | Acer Aspire 5920-6727 Notebook
I have an acer aspire 5920 and it will not power on. It stopped working while someone was using it. I've already taken out the battery and unplugged it, nothing worked.
sounds like the power adapter or the unit itself. hopefully, it's just the power adapter-- was there/is there a light on it that tells you its plugged in or charging the computer? is that light still on when you plug in the computer to charge it? if not, call acer for a new power adapter, it's usually free if you're under warranty. if it's on, you may be in trouble that the computer is dead-- maybe a fried motherboard. to replace a motherboard is probably 200 bucks, to get a new low-end laptop is 499.... at least in the US, I dont know where you are,
Feb 01, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5920-6864 Is not turned on
this probleme is common among acer 5920, the probleme is with the motherboard that's of bad quality and workmanship. Acer should be ashamed to sell a PC with a faulty motherboard and should compensate all 5920's owners or replace with a better motherboard. 1000's if not millions are having the same probleme wich tell to anyone with a brain that Acer 5920 is a scam. good luck. x
Dec 20, 2008 | Computers & Internet
Computers & Internet Logo
497 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
