Question about Toshiba Satellite A100-S8111TD Notebook
System32\DRIVERS\pci.sys missing or corrupt
System32DRIVERSpci.sys missing or corrupt
  • 37 Answers
The file is corrupted. find a replacement
Posted on Nov 13, 2009
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
The following file is missing or corrupt system32\DRIVERS\pci.sys
Windows system files have become corrupted. You can try to Repair your Windows or re-install a fresh copy using the Windows installation CD (for Repair choose R when prompted).
Jan 24, 2011 | Dell Inspiron E1505 Notebook
I turn on my Eee pc and it says a file:system32\Drivers\Nfts.sys has corrupt or gone missing
I would take it to a local shop to get it fixed. If you have to ask, it is most likely beyond your skills.
This issue is known to be caused by one or more of the below causes.
  1. Other software or malware corrupts or deletes the ntfs.sys file.
  2. Overclocking / heat related issues.
  3. Corruption in the computer memory or memory in computer is bad.
  4. Other serious file corruption issue.
  5. Other hardware confliction or issue.
Aug 12, 2010 | Computers & Internet
One of the disks in not readable and while booting i get a message of pci.sys file missing or corrupted and i cannot start the system
expand the missing/corrupt file from i386 on your installation media to the system32 directory on the server using the bootable OS CD, select the recovery console option, not the repair OS option.
Dec 21, 2009 | IBM x3400 Server
Boot failure. I get this message: Windows could not start because the following file is missing or corrupt: system32DRIVERSpci.sys
For what i see in forums, this issue is really hard, since u cant even start windows in safe mode cuz its one of the drivers that loads even on it. I suggest u try to run the repair windows option from a Windows CD, or even reinstall windows.
U could try to look over the internet for a pci.sys file and copy it via ms-dos if u know how to work on it.
Nov 01, 2009 | Dell OptiPlex GX270 PC Desktop
I am having trouble running setup on my desktop
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
Aug 28, 2009 | Computers & Internet
IBM server dc can't boot due to system32\drivers\pci.sys missing
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
May 23, 2009 | IBM eServer xSeries? 206m
System32/DRIVERS/pci.sys
ITS EASY JUST COPY THE FILE pci.sys from any other computer from System32/DRIVERS/pci.sys .SOUNDS FUN?BUT I KNOW IT WORKS
Mar 27, 2009 | Computers & Internet
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
Toshiba Satellite A100-S8111TD Notebook Logo
381 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
