Question about Car Audio & Video
Im trying to wire up one 1252w 12'' subwoofer, but which ever way i wire the channels up for the ohms all i get is small static sound and no bump?
  • 11,896 Answers
Put Positive wire on Right Channel Positive,
Put Negative wire on Left Channel Negative.
Make sure cross-over is not turned on and turn up all settings to 3/4 and adjust the rest from the cd deck
Posted on Nov 13, 2009
How should i hook up a visonik class D vxd709 to my dual voice coil 12" Treo subwoofer?
if your amp is a monoblock 2 ohm stable amp wire the coils positive to positive and negative to negative into a single channel that will create a 2 ohm load turn your amp down and adjust by ear till it sounds good if your amp is a 2 channel amp 4 ohm per channel wire each coil one per channel turn amp down and adjust by ear till sounds good hope i was helpful
Feb 17, 2013 | Car Audio & Video
Hello..im trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
How do i wire 12"
it depends on the equipment you have and what your trying to do. what are the ohms rating of the speakers- are they dual or single voice coils? what kind of amp are you using? 2-channell 4- channell- or a mono ? if its a mono or a 2-channell what impedence are they stable down to?(ohms)
Dec 11, 2010 | Car Audio & Video
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    I have a four channel rockfor fosgate amp and I need to know hows the best way to connect Infinity Reference 1252w Car Subwoofers
    Rockford fosgate usually work best with 2 ohm speakers. Depending on the resistance of your speakers, will then give you best connection. Check the resistance for the subwoofers. If the subwoofers are two ohm then connect them directly right and left. But if they are 4 ohm connect them parrallel (positive to postive, negative to negative and bridge the amp.) Good Luck, please rate.
    May 26, 2010 | Infinity Reference 1252W Subwoofer - 12"...
    How to wire 12 in sub 1252 infinity
    http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
    go here put in your specs and you have your answer :]
    Oct 04, 2009 | Infinity Reference 1252W Subwoofer - 12"...
    I have a 12" xs that has dual 1 ohm vc`s...how do i wire it to get a 1 ohm load?rick
    Im sorry but thats not gonna be possible with a single sub with dual 1 ohm voice coils. You can wire it to achieve 2 ohm or 1/2 ohm. You will need to add a second sub to get to the 1 ohm mark.
    play around on this site for some clarification: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12
    Oct 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
    Inifinity 1252w subwoofer
    this is probably due to the box they are in. it seams that your box is tuned to a lower freq then the bass hits that are popping. message me with the box dimensions and the speaker parameters
    May 28, 2008 | Infinity 1250w Car Subwoofer
    Car Audio & Video Logo
    15 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
