Question about OKI C5510n MFP All-In-One Led Printer
Unable to get oki c5510 on network. Doesn't seem
Unable to get oki c5510 on network. Doesn't seem to be getting assigned an ipaddress from router. am using straight through network cable. DHCP is enabled on router, disabled on printer. Gateway on printer does not match gateway of actual router, when i try to change printer gateway, it says invalid setting.
  • tony_loftus Nov 13, 2009
    cancel this. Don't know how to delete this. Sort of cleared up the issue.
    Genius:
  • 2,785 Answers
Plz enable the dhcp on printer and try
Posted on Nov 13, 2009
Oki C5510 'Unable to detect printer'
If you have all the led's lit and they are not flashing it means the printer is in download mode. In other words its waiting for you to download new firmware. Look at OKI's site and find the firmware and follow the instructions. That's why you cant install drivers because the printer no longer knows what it is!
Jun 17, 2017 | OKI C5510 MFP All-In-One Led Printer
Avaya 1616 IP phone doesn't take the router IP when assigned statically. There is no DHCP. It shows Bad router after the phone gets a restart.
bad router means that you assigned an IP in the router section, that can not be found on teh network.
You dont have a DHCP server on the network?
Sep 13, 2011 | Avaya 1616 IP Phone
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Is there a Windows 7 driver for a OKI C5510 MFP?
No not as yet i think there still having problems with vista drivers.
Nov 23, 2009 | OKI C5510 MFP All-In-One Led Printer
I have a new eeepc 1002HA and I have been unable to connect to the internet inspite of having good signal for available home network. Can you please help me
if your pc needs internetconnectivity it needs an IP address. If the router on your home network assigns IP addresses because the DHCP server is active then you only need to set "automatically get an IP adress" of the network card of the eeepc.
In any other situation you need to give the network card manually an ipaddress, ip gateway and dns server.
what is your situation
Oct 12, 2009 | ASUS Computers & Internet
Computer cannot see Oki c5510 in network.
It's very possible that with a reboot of the printer and/or your router that DHCP assined a new IP address to the machine. Look in your router settings for the active clients and look for the IP address of the printer. Than go into your printer management within Windows, check the IP address assigned to the printer and change it to match the IP address you found on the router. It's happened to me before and it can be very frustrating.
Aug 08, 2009 | OKI C5510 MFP All-In-One Led Printer
OKI C5510 - when printing on photo paper, makes goo all over and photo does not print properly??
you must choose the thickest media type possible at the printer and on the pc. your fuser is not fusing properly causing toner to goo on the roller, changing to thick paper increases temp and slows printing to ensure bonding. some coated papers do not work well with OKI printers. you should check mnf website for specs and recommended papers types
Aug 04, 2009 | OKI C5510 MFP All-In-One Led Printer
Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
I cant log into my router even though I am using the 192.168.1.1 subnet mask
Go to run type in cmd a dos prompt will appear.
type in ipconfig /all and check your ip address. Chances are your ip address is 169.x.x.x which is an internal ipaddress. You will need to manually assign an ip address To do this go to my network click on view connections right mouse click the lan icon then go to the tcp/ip config and manually assign your ip address.
It needs to be the same subnet as your router so use 192.168.1.xx anything but 1 then you should be fine.
good luck
Jan 13, 2008 | NetGear WGR614 Wireless Router
OKI C5510n MFP All-In-One Led Printer Logo
358 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
