Question about Thermador 42 in Built in Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4255E / KBUDT4255E
Hello, my 3 year old thermador is not cooling. fan is on, lights and water but it won't cool. digital control is showing 70
  • teoge5 Nov 13, 2009
    how to i check wich one is faulty, thank you
  • 11,896 Answers
Either thermostat or compressor is faulty.
Posted on Nov 13, 2009
  • Nate Stansfield
    Nate Stansfield Nov 13, 2009
    You can use an ohmmeter. You can also get manual and diagram at repairclinic.com or partselect.com
C302U Double Oven cooling fans shut off immediately after finishing bake cycle. Replaced control board, still does the same. What controls the cooling fans to protect the circuitry?
Newer versions of the control board software will run the cooling fans for a bit after the cycle ends, but many older models work like yours does
Aug 30, 2016 | Thermador C302U Electric Double Oven
I have a 2003 Jeep Cherokee Laredo, 6 cyl, which has a 2 year old radiator, changed thermostat, water pump, the fan runs, and still overheats to the point the engine raddles and turns off. The radiator is...
SOUND LIKE COOLING FAN NOT WORKING.YOUR VECHICLE HAS A HYDRALIC ELECTRIC COOLING FAN CONTROL BY PCM.TAKE JEEP TO THE GARAGE THEY HAVE TO USE A DRB 3 SCAN TOOL TO PULL UP ANY FAULT CODES.
Apr 19, 2010 | 2004 Jeep Grand Cherokee
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Not cooling/freezing THERMADOR SIDE BY SIDE REFRIDGERATOR BUILT IN
Sounds like thatyou refrigerator has leaked out the refrigerant. If you have a condenser i.e. cage on the back , place your hand over it and see if it is warm if it is not then if deffinaltey the gas.
this is not a diy job and you will need an engineer with relevant qualifications..
hope this helps
cheers wash doctor
Aug 25, 2008 | Refrigerators
F64 code on lower oven of thermador model cm302
Go to:
http://www.assuredparts.com/ThermadorRangeFaultCodes.html
F64 Lower oven cooling fan air switch not detected Replace air switch,replace cooling fan,check connections, check P6 on PCB control display.
f64 fault code is an issue with the lower oven cooling fan motor and, or (air) sail switch
Apr 12, 2008 | Thermador Kitchen Ranges
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Thermador built-in double wall oven -- replace cooling fan?
No, do not try it yourself. When the motor is bad sometimes it won't have the power to start itself. With a push it will take off. If you try to remove it yourself you will risk damaging cabinet, the oven itself, floors and/or yourself. Please trust your repairman. We are trained and experienced. Not everyone Is out to get you!
Feb 11, 2008 | Thermador Ovens
Thermador 42 in Built in Side by Side Refrigerator w/ Masterpiece Handle - KBUIT4255E / KBUDT4255E Logo
159 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
