Can't find and install driver software for my t-flash disk Message says,Microsoft WPD file system volume driver
  • 11,896 Answers
You can download from microsoft, or softpedia.com or download.com or many other sites. You will need to reset the pc after installation.
Posted on Nov 13, 2009
DELL INSPIRON 1750 stuck in start up loop error code OFOO:
HI,
Could be you just need to update your drivers, before you take it apart try this:
Follow the steps mentioned below to check what Updates are installed on the system.
See which Windows updates are installed
http://windows.microsoft.com/en-US/windows7/See-which-Windows-updates-are-installed
Error Code 0F00:133C
Msg: DISK- No suitable disk media is present.
This error message is encountered when you probably have a bad video card and/or flaky RAM.
Step 1:
Unplug all the External devices such as printers, scanners etc and check whether you encounter this error message.
Step 2:
I would suggest you to install the latest drivers for the Video card from the dell website and check
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
For further reference check the article mentioned below.
Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Step 3:
Iwould suggest you to configure Chkdsk to run when the system restarts next time. Follow the steps mentioned below to configure Chkdsk to run when the Windows Vista restarts next time.
a.Click Start and then Run.
b.In Open, type cmd and then press ENTER.
c.Use one of the following procedures:
Procedure 1: To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
Procedure 2:To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note: If one or more of the files on the hard disk are open, you will receive the following message:
a.Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
b.Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
Procedure 2: To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
I got this information @ 0F00 133C Error Code No suitable disk or media is present written by Thahaseena M, Microsoft Answers Support Engineer.
Feb 16, 2014 | Dell Inspiron Computers & Internet
I'm needing a driver for my FE-280
To read the manual you will need Adobe Reader (free)
If needed, use the Get Adobe Reader Button on the following link
http://www.adobe.com
Instruction Manual from the following link documents software installation and use.
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1318
This is not a driver per say but it appears to be the software you require. It is listed as Vista compatible
http://www.olympusamerica.com/cpg_section/oima_softwareMaster.asp
I hope this is the complete software however I belt it inappropriate for be to register for the software since I do not own the camera.
Jan 04, 2008 | Olympus FE-280 Digital Camera
Wpd can't load
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
May 01, 2012 | Microsoft WPD FileSystem Volume Driver
Not working. windows could not load installer for wpd. what is wpd)
Here is what you need to do.
Explore your drive C: (usual drive where windows operating system is installed)
Open your Windows Folder and look for the files SFCFILES.***
If you see filename SFCFILES.OLD, replace its extension with DLL (like SFCFILES.DLL)
If you don't see this file, you can copy thi file on the directory of ....\I386 on your windows cd installer.
This file when copied in the cd installer has .DL_ extension. Just replace it with .DLL extension and copy this file on C:\windows\system32 directory.
Try this and let me know.
Feb 03, 2011 | Samsung SES084CUSBS Black 8X USB 20 DVDRW...
I have lost the installation disc for lexmark x4690and cant find the driver on the internet
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
Or go straight to driver page for your system:
Driver for Microsoft Windows 2000, XP and Vista.
Driver for Microsoft Windows 7.
Driver for Microsoft Windows 7 x64.
Driver for Microsoft Windows XP x64 and Vista x64.
Driver for Mac OS X 10.6
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then ifyou get in troubles, followthe instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Nov 12, 2009 | Lexmark X4690 Wireless InkJet Printer
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
Pen drive problem
hi.
Vista doesnt recognize all pen drives. only few like Sandisk, Transcend etc get recognized. Even brands like kingston don't get recognized. so to make them work install the driver for the pendrive. If you specify the brand of your pen drive ..i will try to help out with a driver .
regards
bzoy
Dec 11, 2007 | Transcend (589307) Media
Bsod when i tried to install win2k
Error Message: PAGE_FAULT_IN_NONPAGED_AREA
Explanation:
This Stop message occurs when requested data is not found in memory. The system generates a fault, which normally indicates that the system looks for data in the paging file. In this circumstance, however, the missing data is identified as being located within an area of memory that cannot be paged out to disk. The system faults, but cannot find, the data and is unable to recover. Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
User Action:
This Stop message usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, either main memory, L2 RAM cache, or video RAM). If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. Run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Another cause of this Stop message is the installation of a buggy system service. Disable the service and determine if this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. Antivirus software can also trigger this Stop message. Disable the program and determine if this resolves the error. If it does, contact the manufacturer of the program about a possible update. A corrupted NTFS volume can also generate this Stop message. Run Chkdsk /f /r to detect and repair disk errors. Restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk. Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver causing the error. Disabling memory caching of the BIOS might also resolve it. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Nov 20, 2007 | Microsoft Windows 2000 for PC
I had this same problem, I'm using Vista on my HP laptop and I managed to correct it. Apparently HP like to customize Vista and when connecting some USB device's they don't recognise them as what they should. A USB mass storage device. You will need to connect the camera to the computer, the camera will come on then click the ok button so it selects PC. Wait until it finishes its search click cancel and open device manager, scroll down and below Network Adaptors you should see an expandable tree with an yellow exclamation mark named Portable Device's --> FE-280/X820/C520 you will need to right click on the FE-280/X820/C520 icon and select "Update driver software". Then select "Browse my computer for driver software" then select "Let me pick from a list of device driver's on my computer" Scroll down till you see "Universal serial bus controllers" then select "USB Mass storage device" in the next window. It should all work fine now! If it still doesn't work try selecting "Portable devices" then select "WPD File system device" --> "Microsoft WPD filesystem Volume Driver".
Hope it helps.
Cheers, Mick
Nov 18, 2007 | Olympus FE-280 Digital Camera
222 people viewed this question
 Grubhead
Grubhead
