Question about LG CHOCOLATE VX8500 Cellular Phone
Charging port is disconnected - LG CHOCOLATE VX8500 Cellular Phone
My new tablet quit charging...I tried another charger and still nothing..
You could have a bad battery or the charge port is bad or disconnected, Look where the charger makes contact and make sure it is not bent and touching the side of the case. If it still won't charge, I bet the inside charge port is broken and you would have to get a new tablet.
Mar 02, 2015 | Tablets & eReaders
Jakks spytech watch only will work when connected to USB port of computer. If disconnected it goes blank and will not operate. When connected toi USB port the following message is the only thing...
The problem is a worn out battery because it is not charging while it is connected to the computer's USB port.
The recharageable battery needs replacing.
Apr 18, 2012 | Audio Players & Recorders
My nokia 1112 is not admitting charge, changed the battery abnd the charger but not working
Since You have changed the charger and the battery and the phone still does not charge then It means the charging/connection port of the phone is bad. And the best solution is to replace the port of the phone. To replace the port is quite simple. First You can charge the battery in another phone temporarily while You get the connection port of the phone fixed. To replace the connection/charging port, please follow the steps below:
  1. First remove the back cover and battery.
  2. Unclip the front cover then remove the four circled screws
  3. You can now remove the LCD frame. Another ribbon connector (circled) needs to be disconnected. This attaches like a plug and socket. Simply lever it up, away from the phone, to unplug it. The LCD is now free.
  4. Then You take out the 4 screws that are around the phone,
  5. That should release the panel of the phone out,
  6. Disconnect the connection port of the phone and replace it with a new one,
  7. Then You reverse the process to reassemble the television back together.
  8. Hope this helped. Thank You for using FixYa!!!
Jan 26, 2011 | Nokia 1112 Cellular Phone
Charging
If the player won't stay on after disconnecting from the USB port, it means that the wire connection between the battery and mini board is either loose or disconnected. Since the wire is disconnected from the battery, the MP3 won't have a power source.
Unlike if it's connected to the USB port, it will turn on because the USB port could provide enough amount of power for the player to turn on.
If the player is still under the warranty, you may send it to the manufacturer for free repair. But if it's out of the warranty period, you may open it and re-solder the wire. Or you may simply send it to a tech to do the fix.
Thank you and good luck!
Jun 27, 2010 | Coby CBY705 MP3 Player
My battery wont charge on my motorola rival i bought a new battery and it still wont charge.
If your phone does not seem to charge. It is as a result of either the charger or the charging port.
To test if it is the charger;
Try to use a tested okay charger on your phone.
Try your charger on another phone to see if it would charge the phone.
If it does not work,then it is the charger.
All you have to do is to replace the charger.
Test if it is the charging port;
Try to use a tested okay charger on your phone,
If it does not charge the phone,
Then it is the charging port that has a fault.
To fix the charging port;
  1. get the appropriate screwdriver,
  2. remove the back cover, the battery and the sim,
  3. Then you will remove the stickers, you will find some screws at the angles of the phone, unscrew them,
  4. Run an object like a credit card around the line across the phone and apply a little force to separate the stainless part of the phone,
  5. You will have access to the panel of the phone,
  6. Try to locate the charging port of the phone,
  7. Disconnect it and replace it with the new you got for it,
  8. Reverse the process to reassemble the phone.
Take care
Jun 21, 2010 | Cell Phones
Battery won't hold charge
The reason your phone is not holding a charge is simply because there is a problem with the terminal head.
The terminal head is malfunctioning and is not charging the battery.
To fix the terminal head,
  1. After removing your back cover and battery, remove the screws you see.
  2. With the screws removed you can now remove the battery compartment.
  3. With the battery slot removed you have access to the terminal head.
  4. it is the metallic sheets that rests on the head of the battery when inserted into the phone.
  5. Get a pin tip soldering iron and disconnect the terminal head from the green panel you will see,
  6. replace it with a new terminal head.
  7. Reverse the whole procedure for reassembly.
Another fault might be the charger or the charging port,
To test if it is the charger,
Try to use the same charger on another phone to see if it will work,
If it does not work then it is the charger.
To test if it is the charging port,
Test a well tested okay charger on the phone to see if it will work.
If it does not then the problem is the charging port and to change it
you follow the procedure of of changing the terminal but you have to disconnect the screen and the remove the charging port and replace it with another new one.
take care
Jun 19, 2010 | LG VX8350 Cellular Phone
Where is the low pressure air conditioner port on a 2007 Tacoma
LOOK FOR A BLACK CAP OR BLUE CAP LOW PRESSURE CHARGE PORT WILL BE ON SAME LINE NEXT TO DRIER OR ACCUMULATOR.OR TO EVAPORATOR LINE.DONT CHARGE PORT WITH RED CAP.THATS THE HIGH PRESSURE PORT AND DISCHARGE PORT.WEAR SAFETY GLASSES WHEN HANDLING REFRIGERANT.VERY DEADLY IF YOU INHALE. R -134 TRY NOT TO BREATHE AROUND IT WORK WHERE THERE IS GOOD FRESH AIR FLOW.
Apr 14, 2010 | 2007 Toyota Tacoma
Garmin Nuvi 200 not charging
I also have a Nuvi 200 that didn't charge. The problem is the charging port disconnected from the circuit board. You can disassemble the unit and reconnect the charging port but it takes a small torques wrench and a small screw driver. You will also need a soldering iron preferably with a fine tip and a very steady hand. Good luck.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Were is the low side cherging port on a 96 lincoln town car
Should be reciever/drier pass side undehood.will be fitting with black cap their.Attach to port with charge line .Must have engine running and compressor on.
Jun 19, 2009 | 1996 Lincoln Town Car
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
LG CHOCOLATE VX8500 Cellular Phone Logo
55 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
