Question about Kenmore 98702 Stacked Washer/Dryer
It wont spin
The wasshing machine doesnt spin
  • 464 Answers
You need to replace the direct drive coupling.
Posted on Nov 13, 2009
Wont agitate or spin everything else working
hi Paulmahoney.
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
read up some more at this link might help you out some more.
Washer Doesnt Agitate or Spin
or this link.
washing machine Wont agitate or spin Google Search
Dec 14, 2017 | Washing Machines
It wont spin out
if it doesnt go into spin brushes in main motor could b stuck or worn check also outlet tube and waste pipe not blocked if it goes into spin but doesnt empty check spin pump not jammed but most common fault brushes in main motorworn
Mar 18, 2012 | Whirlpool Washing Machines
Hi-i have an lg wasshing machine 5.5kg wf-t552c.wont spin outside drum-lower plastic disc in drum spins only-drains water ok.
Now you meant that the agitator shaft works but the drum does not work. So the fault seems associated with the motor drive and could be a belt failure or a drive failure.
In this case it is important that an observsation into the fault from the motor drive is important to confirm the cause as it seems mechanically related.- since all other functions works according to the cycle.
Oct 06, 2011 | Washing Machines
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
I can't locate brushes on Bosch Logixx 1600 wasshing machine
hi
usally the brushes are at the back of the motor but depending on motor they could be inside . to get to these you need to remove the 4 screws wich hold motor together. but 1st thing to check is to look at armitor on motor and see if you can see a line going round in the middle. if there is the motor will probley need to be replaced as the motor will have burnt out. but motors are very expensive o these machines. hope this helps
regards dan
Mar 19, 2009 | Bosch Logixx WFT 2806 Front Load...
My haier washing machine doesnt work properly
get rid of it. I had two of these that did the same thing. people all over the internet are suffering with haier washing machines! They are utter rubbish and I will never buy haier again!
Jul 30, 2008 | Haier 14.3 lb. Washer/Dryer Combo
Hotpoint Aqualtis Error code F11
please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
Jun 27, 2008 | Washing Machines
SUDS appears when I do a wash. Then F-02 appearas and the washer does not spin out nothing happens. I then emptied the tub and left one towel in the machine and put it on the spin cycle and the water did...
Check the exit hose for blockage and kinks,
open the bottom access panel (3 screws front bottom)and then open the filter access and look for debris, some extra water will spill!!,
check the manual for more in this area
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Apr 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
114 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
