Question about Mitsubishi Heating & Cooling
Leaking from the inside unit - Mitsubishi Heating & Cooling
    Problem Solver:
  • 16 Answers
What is leaking? water?
Posted on Nov 13, 2009
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
Why would unit be leaking water on the inside unit
If it is leaking on the inside (coil) it usually is a sign the condensate drain is plugged causing overflow, or the coil is freezing up inside and when its off it thaws the ice and melts down the center of the coil and onto the floor,
Jul 21, 2014 | Ruud Central System Air Conditioner
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
My frigidare frc150ff is leaking. what is the matter with it
The leak may be from the condensation of water. Check the panel at the back of the unit inside it. See if there is ice buildup inside. Remove all ice including the panel. It would be best to clean the unit while doing so. The leak may be from drain being clogged from debris or drain frozen which prevents water to follow the correct path.
Apr 07, 2011 | Frigidaire Refrigerators
Leaking from inside unit
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Jan 15, 2011 | Carrier Heating & Cooling
Water leaks from the roof unit
This is condensate (which of course is water) that is coming from your unit. This is very normal ... Is it leaking inside or running across the roof and down the side of your unit? If it is going inside, there is a drain in your roof unit that is clogged. You must clear the clog. Remove the cover and inspect the base. Turn the unit off first.
Sep 19, 2010 | Dometic Rooftop RV Air Conditioner
Frigidare air conditioner thru wall unit Model FAH146Q2T2 leaking water inside?
Always make sure that your unit is tipped back towards the outside os it does not leak inside...
heatman101
Jun 02, 2010 | Heating & Cooling
New inverter reverse cycle leaking water out the front of the unit. Its 44 degress outside, could this be the problem?
Is it leaking out of the evaporator(inside unit) or condenser?
If it is leaking from the outside unit on defrost then it is normal, if it is leaking from the inside unit then you have a blocked condensate drain tube!
These units defrost from time to time and is normal, it is actually melting the ice that can form on the condenser when it is cold enough outside, it has to initiate a defrost cycle so that air can flow through the condenser again after the cycle is complete.
Then it will return to normal heat pump mode, this is assuming that you have a heat pump.
Jan 11, 2010 | Fujitsu Electronics - Others
Leaking from bottom
Are you sure its not leaking at the top? in any case
call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 09, 2008 | Philips Senseo HD-7810 Coffee Maker
Heating & Cooling Logo
104 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
