Question about Vtech i5866 Cordless Phone
How do I enter the numbers for Set Security Code and Set Number of Rings
  • kathrynwes Nov 13, 2009
    There was no sollution
*#1234
Posted on Nov 13, 2009
How do I change the number of rings before it goes to voice mail
The manual is available from:
http://www.manualslib.com/download/678020/Vtech-Cs6859.html
( be sure to ignore the advertising large button
"start download" and use the smaller button "download"
across the top banner "downloads" "table of contents" etc. )
then enter the security-codes & click "Get Manual"
then click 'Download pdf'' etc. )
The directions to set the number of rings for the
Answering System are on page 51.
To summarize Setting the Number of Rings:
1. press [MENU]
2. scroll up/down to "Ans System" then press [select]
3. scroll up/down to "Ans System Setup" then press [select]
4. scroll up/down to "# of Rings" then press [select]
5. scroll through the choices, at desired one press [select]
6. press [off ] to conclude & exit
May 05, 2016 | Vtech CS6859 Cordless Answering System...
How do I retreive messages from the answering machine remotely?
this is pertinent to uniden dect 1653 series and may work on yours as most uniden systems use the same format
1--call your phone number and wait until the system answers( if it is turned off , it answers after 15 rings and sounds a series of beeps
2--- during the greeting or beeps , press the # and immediately enter your security code . If you enter it incorrectly 3 times , the system hangs up and returns to standby
3--- the system announces the time and the number of messages in the memory and a help prompt. It beeps to let you know it's waiting for a command
4--when you hear the beeping , enter , enter a 2 digit code command from from the chart for example to play a message press# then 2
if you don't press any keys for 15 seconds the system hangs up and returns to standby
the chart codes are
#1---repeat message
#2-- play message
#3--skip message
#4 --delete message
#5--stop play back
#6 turn system on
#9---turn system off
#0 hear help prompts
to get your security code -- programming a security code
the default security code is 80
1-- with the phone in standby, open the menu from any handset
2-- select ans setup, the select security code
3-- use the number keypad to enter a 2 digit security code ( any numbers in the 00-99 bracket) Press menu/ select when you are finished
remember to note your security code
if this doesn't work on your set up go google and type in user manual for (make and model ) cordless phones-- and print out any pdf version down loads
Jan 09, 2016 | Uniden Lands Phones
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
Change code number to a new number on safe e.d.safe s25ebf
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Aug 04, 2011 | Office Equipment & Supplies
How do you retreive messages from another phone on the att model 1719 answering machine?
Dial your number, when the AT&T 1719 answers and the announcement begins playing(if the unit's answer function is turned off, it will answer after 10 rings) dial your three digit security code(default is 500). If the announcement continues playing after entering the security code, press # to end the announcement or wait for the announcement to end and re-enter the security code. The answer machine will announce the number of messages then begin playback of the messages. I have included a link to the manual, remote operation of the AT&T 1719 answer machine is on page 8.
http://dl.owneriq.net/3/36b2e479-eaef-8ce4-d522-0a21f4138627.pdf
Feb 22, 2011 | AT&T 1719 Digital Answering Machine
Retrieve Messages when away from home
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home
Sony TAM-100 Answering Machine
Step I: Set the Remote ID (security code) on themachine itself:
1 Press (SET/REC).
2 Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code. To select, pressthe SKIP or REPEAT button. To enter,press the SET button”.
3 Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW). Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4 Press (SET/REC). The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code). The new code will replace the old one.
Note: If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
Oct 24, 2008 | Sony TAM-100 Digital Answering Machine
I have a hyundai sonata classic 2000 model disconnected the battery lead to clean them, now the radio will not work I have a security code but not sure how I put it in to radio
Once you turn on the unit, "1 CDE" will appear on the LCD. Then using preset button 1~4 enter the 4 digit security number supplied on security card. After confirming the number, press preset button 5. This should unlock the player. If the incorrect code is entered "2 CDE" will appear on LCD and if incorrect code is entered again, "3 CDE" will appear on LCD. If, after the third attempt, the code is incorrect, the set will turn off. Wait 1 hour before re entering a security code.
Aug 26, 2008 | 2000 Hyundai Sonata
Factory ringtones
Sir,
You can lock your phone manually or set the phone to
lock automatically whenever you turn it off.
To use a locked phone, you must enter the unlock
code. A locked phone still rings or vibrates for incoming
calls or messages, but you must unlock it to answer.
You can make emergency calls on your phone even when
it is locked (see page 68).
Locking Your Phone Manually
Find the Feature > Settings > Security
> Phone Lock > Lock Now
Unlocking Your Phone
Tip: Your phone’s unlock code is originally set to 1234.
Your service provider may reset the unlock code to the last
4 digits of your phone number.
Setting Your Phone to Lock Automatically
You can set your phone to lock every time you turn it
off:
Find the Feature M> Settings > Security
> Phone Lock
> Automatic Lock > On
If You Forget a Code, PIN, or
Password
Note: Your phone’s 4-digit unlock code is originally set to
1234, and the 6-digit security code is originally set to
000000. Your service provider may reset the unlock code
to the last 4 digits of your phone number before you
receive your phone.
Press To
1 keypad keys enter your unlock code
2 OK (+) unlock your phone
> Phone Lock
Master
Clear
Clear all user settings and entries
except SIM card information, erase all
downloaded pictures and sound files,
reset all options except unlock code,
security code, and lifetime timer:
M > Settings > Initial Setup
> Master Clear
Caution: Master clear erases all
user-entered information (including
phonebook and datebook entries) and
user-downloaded content (including
photos and sounds) stored in your
phone’s memory. After you erase the
information, you cannot recover it.
Thanks
Good Luck
Don't forget to rate the solution
Jul 05, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
Need to unlock my phone
If You Forget a Code, PIN or Password
1234 and the 6-digit security code is originally set to 000000.
Many service providers reset the unlock code to the last 4
digits of your phone number before you receive your phone.
If you forget your unlock code, try entering 1234 or the last 4
digits of your phone number. If that does not work, do the
following at the Enter Unlock Code prompt: Tap (MenuButton) to display the
unlock code bypass screen. Enter your security code, then
tap OK to submit the security code.
If you forget your security code, SIM card PIN code, PIN2
code or call barring password, contact your service provider.
Jan 31, 2008 | Motorola Mobility A780 Cellular Phone
Vtech i5866 Cordless Phone Logo
69 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
