I have 2 problems with my AEG Lavamat 981. 1. The drum won't empty out. We have tried using the emergency drain and even removed the hose connecting the drum and the pump(at the pump end) but the water won't empty out. The pump seems to be working fine i.e.it spins. 2. Before the above problem occurred, if we didn't remove our washing at the end of the cycle it would get wet again, indicating the water was flowing back into the machine at the end of the cycle (I think!). Cheers Brent
  • 155 Answers
First if you drum is filling again after wash you may have a faulty hot or cold inlet valve turn water taps of after wash has finished if no water in drum the next day just a matter of isolating which valve it is
your second problem sounds like you have a blockage in the hose coming out of your drum to the water pump may be that missing sock you were looking for hope this helps let me know how you went
Posted on Nov 13, 2009
Testimonial: "The drum drain pipe had a one way valve in the top that was blocked by a coin. Haven't tested it yet but hopefully this also explains the problem."
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
I have a new AEG Lavamat Turbo L16850 machine. On delivery, it is entirely dead; no display, lights or anything. I have checked packing bolts removed, power on, fuse changed, door fully closed. Still no...
I have exactly the same problem - but with the additional concern that there was water in the outlet hose & the drum was damp. Who did you purchase yours from? What was the outcome? My machine arrived yesterday evening (Friday) & there's no customer service over the weekend.
Nov 26, 2010 | AEG Lavamat 72640 Front Load Washer
How to deactivate EFO on Lavamat 76819?
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 03, 2010 | AEG Lavamat 74640 Front Load Washer
AEG OKO LAVAMAT 72630 is showing E20. what does it mean?
Error code E-20 means drain problem. It means that the machine is not draining water correctly. Check the drain hose, to see if it is kinked or folded over. It could also be that the drain pump or drain hose are clogged. Drain the pump (check behind the little panel at the bottom right of the machine), first draining via the small emergency drain hose if you want to avoid a large puddle.
Also get the fluff filter removed and checked.If the filter is clogged then it will not let the water to get drained. The fluff filter is behind the little trapdoor below and to the right of the drum on the front of the machine. Open the door, unscrew the filter, and pull it out. It will be covered in smelly slimy multi-coloured fluff, which you need to remove. When you remove the filter, there is a good chance that a fair bit of water will come out at the same time, so, if you can place a very low bowl or similar below the filter before you unscrew it it will save you from having to mop the floor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 28, 2010 | AEG Lavamat 72640 Front Load Washer
E20 what does that mean?
E20 is a drain problem. Clean out the drain filter, normally found bottom of machine. Do emergency drain first or you will flood the room if there is water sitting in drum. Hopefully you just have a blocked filter or pipe, otherwise you may have to replace pump if it has failed.
Jan 18, 2010 | AEG Lavamat 72640 Front Load Washer
Water will not drain properly leaving a very wet load ... screen says drainagae blocked
Check two things:
Clean your strainer, located behind the kick panel at the lower front of the machine. It will be in between the drum and the pump, and will have a lid that unscrews.
Check your Drain Hose: The easiest way is to remove it from the house drain, and empty it into a bucket. If at all possible, point it outside and run a cycle with fresh water only.
The strainer will probably fix you up, and usually makes the clothes smell better too.
Best regards, --W/D-- please feel free to rate this solution..thanx!
Aug 01, 2009 | AEG Lavamat Lavalogic 1600 Front Load...
Machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
Jun 01, 2008 | AEG Lavamat 88840 Front Load Washer
147 people viewed this question
 Grubhead
Grubhead
