Question about Euro-Pro Deluxe 7100 Mechanical Sewing Machine
How to thread an omega deluxe denim sewing machine
forgot
  • 17 Answers
SOURCE: baby lock denim pro
try putting some bee's wax around your spool
Posted on Dec 09, 2007
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
SOURCE: A MANUEL FOR A SIMPLICITY SEWING MACHINE MODEL 237
To find the manual online goto simplicityhomecare.com. Under the PRODUCTS tab you'll see Instruction Manuals. Click on that and you'll have a choice of what machine you need an instruction manual for. Look under the Sewing Machine and you'll see the SL237 - Denim Expert. Hope this helps!!
Posted on May 01, 2008
  • 323 Answers
SOURCE: Deluxe denim euro pro
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on May 19, 2008
bargainbox
  • 1388 Answers
SOURCE: HUSKY DELUXE SEWING MACHINE
Your local Husky dealer or via their head office in your country ought to be helpful unless they are out of print.........if so, ......Try sewusa.com or sew4less.com
Posted on Jun 02, 2008
How to thread and set the tension on my Omega sewing machine model 3730 m please help
http://www.howcast.com/videos/214712-How-to-Thread-a-Sewing-Machine
Jul 31, 2014 | Omega Sewing Machines
Need a manual for Omega Deluxe Denim 7500 sewing machine
go to the site of a1sewingmachines.com and call them about a
manual
Mar 05, 2013 | Sewing Machines
I need a replacement feed dog and a striker plate for the Euro Pro Deluxe Denim Sewing machine model 1262D
here are 3 sites to email about the parts you need
sewingpartsonline.com
sewvacdoctor.com
Aug 03, 2012 | Euro-Pro Sewing Machines
I need to get a manual for an omega deluxe denim sewing machineModel 7500
email these sites about a manual
sewusa.com
sewvacdoctor.com
Jun 01, 2012 | Omega Sewing Machines
I'm looking to get a manual for omega denim deluxe machine 7500 model
sewusa.com
sewvacdoctor.com
Jun 01, 2012 | Sewing Machines
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
I need a replacement Auto needle threader. There seems to be no where that I can find the pat numbers for anything on the machine....Euro-Pro 9106 Deluxe Denim & Silk sewing machine.
I've never had an auto needle threader work properly for very long. My suggestion is to not bother to replace it and just relearn how to thread the needle. Sorry.
Jan 13, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Trhreading
http://cgi.ebay.com/Euro-Pro-Deluxe-Denim-Silk-Sewing-Machine-EP-377_W0QQitemZ8271336746QQcategoryZ3118QQcmdZViewItem#ebayphotohosting If so it threads just like my sewing machine.Draw your thread across the top,down into the first slot,then up and thru the second slot,come down,pass it thru the thread guide on the needle,then thread your needle.Most all machines are basic when it comes to threading.HTH
Kathi
May 20, 2009 | Sewing Machines
Euro-Pro Deluxe 7100 Mechanical Sewing Machine Logo
1,666 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
