I need an exterior halogen bulb for the g.e.
I need an exterior halogen bulb for my G.E. Profile Micro. Where can I get them? thanks, Marilyn
    Problem Solver:
  • 7 Answers
You either have to call Microsoft (and it might be covered by your insurence or warrenty), or you can take it to a place near you that can fix your computer. Or, call Geek Squad that's in your area!! I hope that helps!
Posted on Nov 13, 2009
  • 8,404 Answers
Please check with a local electric eupply or appliance parts house or www.repairclinic.com or maybe a FixYa.com advertiser.
Thanks for posting your question at FixYa.com
Please vote
thanks
a
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
Jun 26, 2014 | Kenmore Microwave Ovens
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
I need a halogen bulb to replace the original one in my nexstyle range hood
So where do we buy the bulbs? We've been looking for ages. Thanks.
Sep 23, 2012 | Kitchen Ranges
I need to change a dead bulb in my headlights and I dont have the owner manual.
96 sable, only ino I have. should be similar. Please rate, thanks
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    NOTE: A properly aimed headlamp (13008) assembly normally need not be re-aimed after installation of bulb. A burned out headlamp bulb and retainer (13N021) should not be removed from the headlamp until just before a replacement headlamp bulb and retainer is to be installed. Removal of a headlamp bulb and retainer for an extended period of time may allow contaminants (dust, moisture, smoke) to enter the headlamp and affect the performance of the headlamp. When servicing the headlamp bulb and retainer, energize the headlamp bulb and retainer only while it is contained within the headlamp body.
    Make sure headlamp switch (11654) is in OFF position.
  1. NOTE: On some models the clamps holding the integrated relay control module (IRCM) may need to be unsnapped and the module pulled aside to gain access to the driver side bulb.
    Open hood and locate headlamp bulb through hole in upper radiator support assembly.
  1. Remove headlamp wire connector from headlamp bulb and retainer by pulling the connector and wires in a rearward direction.
  1. Remove headlamp bulb retainer (13N019) by rotating counterclockwise (when viewed from rear) about one-eighth turn and sliding headlamp bulb retainer off headlamp bulb and retainer. Keep headlamp bulb retainer as it will be used again to retain new headlamp bulb and retainer.
  1. Carefully remove headlamp bulb and retainer from opening in headlamp bulb (13007) by gently pulling straight out of opening. Do not rotate headlamp bulb and retainer during removal.
Jul 05, 2009 | 1991 Mercury Sable
Need to replace the surface light in GE JVM1490BD 003
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Or you can find helpful exploded view diagrams and order parts by entering your full model number here.
You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jun 28, 2009 | GE Profile Spacemaker 1.8 Cu. Ft....
Need to replace halogen bulb that illuminates Advantium interior
Mine is installed also, and I've had to replace the bulb twice. I wised up the second time and installed an access hole where I can pull my microwave out about 6" and access the bulb. I use a 35 watt 120v halogen bulb, with a GY 8.6 base, Lowe's part number 15797. If your's is different, the specs will be stamped on the metal beside the reflector when you remove the sheetmetal. You have to remove the microwave completely from the cabinet and remove the sheetmetal case that surrounds the entire unit. You can then access the lamp socket by looking in from the top. The first time, I took out the reflector with the socket. The bulb can be replaced by removing the two small screws adjacent to the socket on top of the reflector. My access port is a hole cut into the top. I cover the hole with a piece of sheetmetal and two sheetmetal screws. Seems to work just fine. If you do decide to cut a hole, do so with the metal enclosure off and away from the microwave to avoid getting any metal shavings into the machine!
Regards! --W/D--
Feb 17, 2009 | GE Profile Advantium SCB2001KSS Stainless...
GE Profile JE1590--light bulb
The type of screw attaching the casing is called a Torx Tamper Proof screw. You need a Torx Tamper Proof Screwdriver to remove the screws. These screws and screwdrivers come in various sizes. I think the size you need is T20H.
Nov 19, 2007 | GE JE1590 Convection / Microwave Oven
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
