Question about RCA Universal Remote Control
I have an RCA universal remote with code search and can't program it to my Magnavox TV
  • 325 Answers
Hello Working Man 04
Here are some codes for you:
Magnavox 006,007,010,011,013,016
hope this helps you out. If it does then please leave a thumbs up
Cheers Little Dish Fitter.
If your still having problems here is a link for you..
http://www.universal-remote.net/rca.html
Posted on Nov 13, 2009
CompuGuy44
  • 432 Answers
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
This website should help.
http://www.thompsontv.com/rcarc.html
Posted on Nov 07, 2007
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
Posted on Jun 13, 2008
robotek
  • 1512 Answers
SOURCE: Programming a RCA Universal remote to a magnavox tv
Hi tinalynn1071
I couldn't find the book anywhere for you,but did find a guide on programming RCA universal remotes, and a list of standard codes you may wish to try:)
regards
robotek
Posted on Jul 16, 2008
MediaMan85
  • 163 Answers
SOURCE: rca remote with no code search button
You didn't mention the model of the remote so try http://www.fixya.com/support/t839679-rca_remote_no_code_search_button
and see if it is listed.
If this works please repost,
MM85
Posted on Jul 27, 2008
VOTIT
  • 2071 Answers
SOURCE: ive got a rca universal remote without a code search button how do i program it?
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Jan 08, 2009
I have a Magnavox sdtv converter TB110MW9 the remote stopped woring. i now have a RCA RCR314WZ/RCR313BZ universl remote. Can't seem to program it. Please help if you can, send codes.
Some of the newer RCA universal remotes can handle STBs. Use code search to find something suitable. If a search through all codes contained in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Aug 15, 2016 | Magnavox TB110MW9 DTV Digital to Analog...
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
How do I program my RCA universal remote for my Magnavox TV?
Your RCA universal remote has a code search feature you can use to find a suitable code. If you search through all codes stored in the remote, without success you may have to try another universal remote. All universal remotes do not contain all possible codes.
Aug 25, 2015 | RCA Televison & Video
I have 3 different RCA universal remotes and I cannot program any of them to my Phillis magnavox tv 27ms343s. I have tried multiple codes, auto search, and ways to initiate the code programer. Please help.
You really need to purchase a philips universal remote. Your RCA remote may not contain the option you seek. Some of these TVs are unique and will require the same name brand. Thanks for asking and show a few hands of support!
Oct 02, 2010 | Philips Magnavox 27MS343S 27" TV
Code list
Programming remotes for your devices (TV, DVD players, digsat/cable boxes/DVRs, etc) can be done often in an automatic (auto-code search) or manual (you input the code) mode.
Here are some pages that will help you choose the automatic and manual mode.
http://www.ehow.com/how_9191_program-rca-universal.html
http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button
http://tv.manualsonline.com/manuals/mfg/rca/rca_universal_remote_product_list.html
Nov 08, 2008 | RCA 3-Device Universal Remote with...
RCA universal remote RCU703SP wont program Magnavox TV
cheap universals dont hold as many codes, the best universal remote is the all for one range with the best being the comeleon
Jul 23, 2008 | Philips Magnavox Learning Universal Remote
I need the code to program a magnavox remote to a RCA tv
A magnavox remote should program like the phillips universal. I will post the link. If this doesnt help post the model number of the magnavox remote that you are trying to program. the model number is usually in the battery compartment.
http://www.universal-remote.net/philipsmagnavox.html
Feb 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Lost my manuel "codes" to my rca universal remote control crk74ba3
magnavox codes, 11454, 10054, 10030, 10706, 11990, 11963, 11944, 11931, 11904, 11525, 11365, 11254, 1198, 10802, 13=0386, 10230, 10187, 10186, 10179, 10096, 10036, 11028, 10024, 10020
Nov 07, 2007 | RCA Universal Remote Control
Televison & Video Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
