Question about iLO (2 GB) MP3 Player
My installation disk won't run
I can't get the installation disk for my ILO mp3 player to run... therefore I can't install the program to organize my player. Help!
I have windows xp and was told that i didn't need the disc for it. it's the cord/cable not communitcating with the mp3 player that's my problem. they told me to try different usb ports on the back of the computer, and it still didn't work. so she said to try it on another computer, but that's a bit redundant, i want it to work on mine.
Posted on Jan 08, 2008
6ya staff
SOURCE:
Tip
ILo Mp3 Player Help is Here
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
on Sep 13, 2008 | iLO (2 GB) MP3 Player
When i turn it on it just shows the ILO symbal and flashes
Hello.
In order to fix Your iLO Mp3 Player please follow these steps:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
    Download the Firmware.
  3. Click Open to initiate the download.
  4. Double click on the ILO or Siren folder icon. There will be 14 icons.
  5. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
  6. The Install Wizard has the instructions on the screen as you go through it.
  7. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Additional Tip: The player itself requires a lot of power while flashing the firmware. We suggest disconnecting all USB devices from the computer except the MP3 player and mouse; you can reconnect your keyboard once the firmware has been flashed.
Good Luck.
Nov 03, 2009 | iLO (2 GB) MP3 Player
I am using Transcend 320GB external harddisk, file name "b12f74d84bc31b0b92c7" was observed, in that subfolder update is there. unable to delete that folder PLZ help me.
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
3.b) Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
May 17, 2009 | iLO (2 GB) MP3 Player
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
Jan 10, 2009 | iLO MP3 Player
Problem with mp3 player
iLO Mp3 Player
"Flash Error"
Jan 06, 2009 | Jwin MP3 Player
Stupid thing
It sounds like you have autorun disabled on your machine. No matter. Insert the disc, click on my computer & you should see the name of the install disc in the drive you put it into. Click on it & look for a file called autorun or one that ends ".exe". It should start installing from there.
You can use any media player (iTunes, Windows Media Player, Winamp) to organise playlists. But you should be able to at least try out your software & see how it measures up.
Jan 10, 2008 | iLO (2 GB) MP3 Player
Ilo 1gb mp3 player
install the ilo driver cd that came with your ilo. Because you never know, not all ilo mp3 players have the same software.
Thats just my opinion, hopefully it works
Dec 30, 2007 | iLO MP3 Player
Installing ilo 2g software
This player is useless - you probably have Vista - it is not compatible
Dec 26, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
35 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
