Question about Dell E228WFP LCD Monitor
After 1 year, the monitor DELL E228WFP started to turn black
After 1 year, the monitor DELL E228WFP started to turn pitch black for no reason after 30 minutes or one hour of use. Everything was still working but you could'nt see anything. I always had to close it with the monitor's power button and reopen it. Thanks,Anna.
  • 732 Answers
Ainamat, Did you do the FLASHLIGHT TEST to evaluate the status of the "switch-mode-power-supply"??? Every owner of a lcd display with "cold-cathode-fluorescent-lamps" backlighting should know how to perform AND interpret the results!!!! It's a very easy test to do! FYI Your monitor has a backlighting sysem very similar to the NEW curlie-Q CFL energy-saving screw-in light bulbs!! They have an ELECTRONIC BALLAST (converter) circuit (ac to ac) to light them. Monitors have a INVERTER circuit (dc to ac) ballast circuit that generates 600-1100vac to light your CCFL's. If the SMPS detects a FAULT with itself or a circuit that it is supplying power to, It will go into SHUTDOWN mode to try and save the unit from a catastrophic, nonrecoverable failure. e.g. worst case sparks,smoke,fire!! Anna, you should READ and follow the threads in my other responses if you can get to my FIXYA profile pages under 12fixlouie, aka louie12fix and read what I have already written about the BLACK SCREEN of DEATH and YOUR options. If after doing some surfing of the net, you determine that this response has steered you to a solution to your BSOD problem, please rate this response on fixya. Good luck in your quest. 12fixlouie
Posted on Nov 13, 2009
Dell E228WFP monitor cutting off, goes black
sysjrm, You need to visit YOUTUBE for video clips of "lcd monitor repair" to see if DIY project is what you can handle!!! After you "learn by seeing" some printed circuit "switch-mode-power-supply/inverter boards" having their "aluminum-can" electrolytic filter capacitors replaced and/or "thermally-intermittant" fractured solder-joints "resoldered" then you will be able to make decision on what to do about attempting a repair to your E228WFP! Note!!!! Make certain that your pc is not the cause of your BLACK SCREEN or BLACKnBLANK SCREEN problem/symptom by connecting a "known-good" monitor to your pc first!!! Please read the higher numbered(32 and up) pages in my fixya profile for more information on how to do the simple "flashlight test" for evaluating the state of shutdown that the switch-mode-supply may be in. Also read and follow the links you find in the profiles of "budmrtn" and "buddymc" that are very good ccfl back-lit lcd monitor technicians here on fixya. After you do your web research, remember to come back to this posting and do a comment and rating of this response if you feel that it has steered you in the right direction. Good luck with the repair. 12fixlouie
Jul 23, 2010 | Dell E228WFP LCD Monitor
My monitor goes black after a while. I can see
That is just a backlight lamp problem. It is necessary to service it. take it to a service center or give me more information to say to you how to do it on your own.
Apr 19, 2010 | Dell E228WFP LCD Monitor
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Dell E228WFP keeps entering powersave mode
disconnect all the cables from the back of the monitor except the power
you would see a test screen
if it still go to power safe while you are in the test page you monitor cud be bad better buy a new one as usually repairs are expensive
Dell e228wfp monitor
in control panel,, go to power option,, go to advanced,, on the option of turn off my monitor,, make it never
Jan 08, 2010 | Dell E228WFP LCD Monitor
Hello I have a monitor DELL E228WFP and it turns black after a while. I have it about 1 year, and it turns black for no reason. I wan't to know how to make the flash light test on my monitor.
Okay, there is what is known as a Diagnostic Partition in all Dell computers. When you turn on your computer you need to Tap F12 when you see your BIOS load (which is the first thing you see on your screen when you turn on your computer.) You will then see several options, if you did it correctly, and the one on the very bottom usually says something along the line of "Boot to Utility Partition" and there will be an option for a screen test. Run it.
Please tell me if you need any further assistance.
Ryan Frame
Creative Energy Associates Technical Center
Nov 13, 2009 | Dell E228WFP LCD Monitor
My monitor randomly turns itself off.
It is the monitor - go to dell thread here
Jun 03, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Monitor blacks out...
You could connect it to a different PC to determine whether it's the monitor or video card, corrupted driver, etc....
Let us know how it goes, and we'll try to help.
Feb 08, 2009 | Dell E228WFP LCD Monitor
Dell E228WFP LCD Monitor Logo
632 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
