Question about Denon AVR-3806 Receiver
Computer to Denon via Monster Headphone cable to V.Aux (Front) RCA inputs
I'm using a Monster cable (Headphone Jack to RCA) to play CPU sound on my Denon AVR 3806. Problem is I get all kinds of feedback....
I looked in the Audio-In setup menu and the only options for V.Aux (Front) are Opt (Optical), COAX or OFF?? No option for RCA??
I've tried them all but I still get tons of feedback and can barely hear the CPU audio -- - Is there a setting I'm missing??
THanks for the help
Are you using a stereo-mini to RCA cable that has a red and a white RCA plug? What I mean is, you should have the one cable coming out of the headphone jack on the computer, and two (left and right) cables going to the receiver. The only other thing I can suggest is making sure the cables are tight. Maybe try another input on the receiver. There really shouldn't be any feedback unless there is some underlying problem.
Posted on Jan 08, 2008
How can I connect my I pod Touch to my Denon AVR 1803 receiver?
The best way to connect an older IPod or other MP3 player to the AVR-1803 is to use a 3.5 mm (M) to RCA audio cable. This will work for audio on all IPods (and video on some of the older IPods). Here's an example: http://www.amazon.com/3-5mm-Audio-Video-Cable-iPod/dp/B000STBSU4 . Connect the 3.5 mm end to the headphone jack; the RCA plugs go into one of the AVR-1803 RCA inputs.
For some IPods, try a connector like this: http://www.amazon.com/Cables-Unlimited-iPod-Connector-Cable/dp/B000CBFVXS . This connects to the docking port on the IPod.
I hope this helps.
Jul 20, 2015 | Denon Audio Players & Recorders
How to connect a walkman to a Denon AVR-3805
headphone jack cable to 2x RCA/phono (red & white) cable. Connect that to a spare input on the amp.
Sep 02, 2014 | Denon AVR-3805 Receiver
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
Same problem as below, I have the Denon AVR 790 and the sound keeps switching to headphones. Blowing into the socket did not help. Both unpluging the AV and putting the headphones in and out fix's the...
The unit thinks there are headphone plugged in even when there are not. You need to have the headphone jack replaced. This is a common problem with this model. Another way to fix it if you don't plan on using the headphone jack is to unplug the cable going to the headphone jack board. This will disable the headphone jack, and stop it from sending an erroneous signal to the micro.
Jan 31, 2014 | Denon Avr-790 - 7.1 Channel Home Theatre...
How do you connect denon avr 1507 to pc? hav used rca but does not register on pc
you should be able to use a rca to mini-plug cable and hook up to the audio out or headphone jack on your pc
Jan 08, 2014 | Denon AVR-1507 Receiver
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
How do I connect my Apple ipod to my Denon receiver:AVR-2805/985?
GET A CONECTION THATS RCA CABLES IN ONE ENND AND HEAD PHONE JACK INTHE OTHER AND CONNECT THE RCA CABLES TO UR INUTS AND THE HEADPHONE JACK TO UR IPOD AND START PLAYING
Jul 01, 2009 | Denon AVR-2805 Receiver
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Denon AVR-3806 Receiver Logo
322 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
