Remote code for nexus television
The only ones I can find are 0463 10463 and 720. If these don't work you could try the auto find method below. As the remote appears to only accept 3 digit codes I'd try 463 and 720. These are known to work on dtv and comcast for this model.
STEP1 Turn on the Component you want to
program (TV, VCR, DVD or AUX).
STEP2 Press the [COMPONENT] button (TV,
DVD or AUX) to be programmed and
[OK/SEL] button simultaneously for 3
seconds. The Component LED will light
for 30 seconds indicating the unit is
ready to be programmed.
STEP3 Point the remote toward the
Component and press the [CHup] or
[CHdn] button one step at a time or
keep it pressed. The remote will emit a
series of ON/OFF commands. Release
the [CHup] or [CHdn] button as soon as
the Component turns Off
STEP4 Test functions. (Same as for 3-Digit Code
Programming Method - Section A). If any
of the functions do not work as they
should, repeat from STEP 3 using [CHup]
or [CHdn] buttons to find the correct code.
STEP5 Save the code.
