Question about Maytag MZD2766GES Side by Side Refrigerator
My icemaker is not working.
I recently replaced my water filter yestereday as it was a year old and my icemaker just stopped working two days ago. Water if flowing nicely to the water dispenser but my icemaker is not working.
  • 725 Answers
Your ice maker has gone out and this is a simple repair to make. Just contact us at :
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST when you are ready to repair this and we will send instructions along with the part.
We look forward to getting you buckets of ice again soon. Thanks, Ella
Posted on Nov 13, 2009
We recently replaced the icemaker in our samsung french door refrigerator,the icemaker worked fine for a few days and now no water goes into it,, we replaced the filter as well
Hi my name is Sean, you will need to check water pressure going into refrigerator, If you have adequate pressure, you either have a bad main board, or bad valve, depending on the year the boards were a problem in this unit affecting the icemaker especially. Let me know if you need further assistance.
Mar 26, 2011 | Samsung RF265AA Bottom Freezer French Door...
We have a side by side Maytag about 5 years old it has been leaking water from underneath for some time and ice forming in the freezer then the icemaker packed up a few months ago, recently our electrics...
this is a big problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Refrigerators
We recently moved and hooked up the water/ice. It
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Jan 09, 2010 | LG LRFD25850 French Door Refrigerator
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker working water not coming through
make sure the ice maker over flow bar is in the down position. if it is up it will cut off the water flow untill the level of ice is reduced. The other possibility is the filter is clogged. If neither of these correct the problem you may have a bad coil on the inlet valve for the water line as it comes into the refrigerator.
Apr 05, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
150 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
