Question about Kitchen Ranges
We have a Kenmore range model 66595012100. When we input the cleaning cycle the digital readout flashes E1F5 and the cleaning cycle does not go on.
  • jhrg Nov 13, 2009
    Thank you. The cleaning cycle has begun.
  • jhrg Nov 13, 2009
    Yes. Your solution worked. Thanks.
  • 6,826 Answers
The code means the door is not shut.The cleaning cycle,automaticaly locks the door,if it is not shut all the way,it can not lock the door,therefore,not going into clean mode,try pushing in on the door as you start the clean mode.
Posted on Nov 13, 2009
On model PLEF398DCH Frigidaire Professional Series electric range, my digital readout for the right side burners works fine. My left side digital readout is inoperative, but the burners work fine. Is there...
Good Afternoon Lee,
I understand that the left hand side digital readout is not working on your Frigidaire range, model# PLEF398DCH. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Once you restore power, you will need to set the clock and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Kitchen Ranges
Whirlpool RS385PXBQ0 slide in range/oven won't work after self-cleaning cycle.
Check the wiring on the door lock. If that looks good you need to replace the door lock but that part is no longer available.
Oct 22, 2013 | Kitchen Ranges
My Kenmore Range Model #95014 is displaying an E1 F5 error and will NOT unlock!
This error code has to do with the oven door lock assembly.
What is the complete model number listed on the unit? Look in the door area or the storage area on the bottom if you have one.
Dec 08, 2012 | Kenmore 95012 / 95014 Electric Kitchen...
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
GE JBP79 door locked, no led readout after self clean
Hello- Control is about 250$. Could save 100$ by installing yourself, but the popular "self-destruct" cycle can cook other switches and what-not. Find a tech and inquire up-front if completed repairs are too high, they keep parts, you pay trip charge.- Hope this helps- ED
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
Kenmore 9114554590 will not bake or broil
The clock/display panel is faulty. There are a few relays on the display that have to work. If the clock is just flashing once with each keypress the the relays are not functioning. The clock/diplay will need to be replaced
Jun 04, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
KENMORE SELF CLEANING FEATURE WILL NOT ACTUATE
Firstly, empty the oven of stuff, including the little thermostat that dangles from the grate, if you value it's life.
Next, close oven door.
Press CLEAN; it beeps and green LED illuminates. LED readout says " -- -- --".
Press the UP arrow; it beeps and LED readout says: ''3:00'', for a three hour burn.
DOOR LOCKED LED blinks while door locking mechanism actuates, then stays on steady. Burner ignites, and it's off to the races.
The exterior of the Range becomes quite HOT, providing an excellent opportunity to educate young children of the concept. ;)
The Cleaning Cycle can be stopped at any time by pressing the OFF/CANCEL button for ~3 seconds. The door will remain locked until the internal temperature of the oven falls below 400F. Nice toy.
Apr 10, 2008 | Kitchen Ranges
Self clean
if your oven has a clean cycle it will say clean on the knobs or a button if digital.self cleaning cycle turns on both broiler and bake elements and temperatures up to 1500 deg.and disintegrates everything in oven also you will have a door lock on oven door
Nov 25, 2007 | Kitchen Ranges
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
