My projecters on my tv need to be adjusted. i was wondering how much that usually costs..
  • 5,138 Answers
Adjust it your self you have a small Black box on it will be 6 controls 3on top for focus R/G/B and on Bottom are 3 screen drive controls R/G/B turn color off on menu then adjust screen drives as close as you can get to a Black and white picture, then go back to menu and turn color back on! with back off clean top of all 3 tube lenses.
Posted on Nov 13, 2009
Colors on my TV seem to be washed out. Convergence is adjusted OK, brightness/color/tint settings don't seem to make a difference. I seem to have bright halos around all light colored images.
The fluid in the picture tubes needs replaced. It is a job for a professional. It usually costs about $250.00 for the job. You might say it's like giving your set an oil change.
Apr 09, 2011 | Philips 50P8341 50" Rear Projection...
Magnavox 9P6034C 60 in. Rear Projection Television Problem. The problem I am having, is that I can not adjust the tint or color, or brightness, whatever I adjust makes no difference. I can move the tint...
This is a common problem with RP Televisions unfortunately. Usually means the tubes are going out. It can be repaired (usually) but it cost quite a bit to fix unless you could do it yourself (which I don't recommend) If that's not an option I suggest going out and buying a new tv. I recommend and LCD or LED though. Not a plasma or rp
Nov 28, 2010 | Philips Magnavox 9P6034C 60" Rear...
Phillips 55" rear projection HD ready --power button lights up, but no picture or sound--just a clicking noise. Also, we can no longer adjust the blue convergence. The adjustment screen comes up, but we...
Got our tv in 2004 and we're having the exact same problem. When the blue convergence started going a couple months ago my husband researched the heck out of it and decided it would cost less to just replace the tv with a newer, nicer model rather than repair it. And now, as of last night, we are having the same power issue where the power button goes on, but won't stay on. It just clicks on and off and no sound or picture. Did you ever get yours fixed, or did you end up replacing?
Oct 15, 2010 | Philips 55PP9352 55" Projection Television
We have a Hitachi big screen, i believe it is one of the last rear projection HD tv that came out prior to the insurge of the flat screens. We need to replace the protective screen and was wondering if...
The screen is composed usually of 3 layers and is very expensive becaus it is a lense. I estimate the cost of the screen at 375$ and labor 200$ by a major player.
Mar 16, 2010 | Televison & Video
Cannot line up colors
Ur convergence it dead.Must change convergence ICS and all it resistors.Buy a convergence kit at Tv repair World.com,Tv repairkits.com to repair it ur self.If u know how to solders?Shop will cost U $300 for parts and labors.
Jan 23, 2010 | Televison & Video
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Convergence IC
Good Day, bpieper65;
You want fix and cost cost? Well if you have skills of soldering of electronic devices you can do this and you can get the parts from B&D Enterprises; 1-800-458-6053;www.bdent.com. Repairing ityour self will cost you about $50.00 and 2.5 to 3.0 hours of work if all goes well.
If you call an Authorized Sevice Center, that will warranty their repair, it will cost between $300.00 to $600.00.
I hope his was helpful, Good Luck, big IRISH.
Aug 19, 2008 | Televison & Video
Blue Projection Gun
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
May 14, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Picture gone.
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Mar 03, 2008 | Toshiba 50H72 50" Rear Projection...
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Jun 15, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
