Question about LG 24 in. LDS 5811 Built-in Dishwasher
-keep getting error message LE -doesn't clean well if it does get through a cycle without error. -sounds like it starts and stops every few seconds.
Same problem as mine and unforutunety fix was a replacement motor which drives pump. Bearings were shot in motor. Lots of people have this problem. If you are good at repair you can buy motor on ebay for $60. Impeller will have to be removed inside unit but motor is on bottom. Lots of screws to get to impeller and gaskets will fall out of place. Motor is easy to remove but gaskets are a challenge to get back after replacement. It will fix the problem for at least a while but It is unclear if the seal in the pump has a design problem and threfore allows water gets to the motor. The bearings fail but I do not know why. Bet LG knows but they are not talking. I hope but get no guidance from LG that the replacement of the motor is a permanate fix. Good luck to us all.
Posted on Nov 21, 2009
  • Ron Davis Nov 21, 2009
    Bad motor due to bearing failure. Motor can be replaced with new one but LG does not tell us if it is a improved motor and a permanate fix. Motor appears to be exposed due to a design in the pump that allows water to leak into exposed bearings. My 2005 dated motor failed after 2 years and I replaced with new one from LG bought on Ebay with recent date code. LG is not telling us if motor design has changed or it will be more of same. Motor is on bottom after impeller and pump inside washer is accessed with lots of screws removed in botton inside. That is easy enough but gaskets are bound to fall out and are a challenge to get back in place. As an engineer I question a design that does not protect the bearings in the top of the motor from getting a drop of two of water into the bearings over time. I would have thought that any engineer in the world would know better than to leave bearings exposed like this with such a simple solution at had like a protector between the motor and the pump shaft. I hope I am wrong but I can not find out if my repair was a permanate fix. Other wise LE all over in the the future. Engineer
    LE means motor failure. Lots of folks getting this and motor replacement due to faulty bearings is a likely cause. Bearings are exposed to water leaking from pump seal as no protection is provided to keep a few drops of water leaking into the motor at the shaft. Even a simple water stop at the top of the motor would have prevented the bearings from being exposed to an occasional drop of leaking from the pump seal. LG has not yet addressed the problem and IMO failure(S) will continue to occur until design is corrected. To remove the motor you must slide the impeller off the motor shaft inside the dishwasher. Be advised it is left hand thread screw holding the impeller on the shaft. Good luck getting all those gaskets back in place after motor is replaced. .
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
Got "LE" mark on LED
Hi
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | Washing Machines
Only pumps water for a few seconds at start of cycle & then stops with 'LE' error code - have tried a few different cycle settings, but same error code comes up
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Aug 22, 2010 | LG Washing Machines
KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
Self clean cycle won't start...get message F5E1
F5E1 error means there is a problem with the door latch or relay.
Mar 27, 2009 | Kitchen Ranges
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
Lg wm2032hw
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
so you need to contact a repairman.
Jan 28, 2008 | LG WD-1280FHD Front Load Washer
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
LG 24 in. LDS 5811 Built-in Dishwasher Logo
159 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
