Question about Cycling
I have a diamondback wildwood citi bike that needs to be disassembled for shipping. How do I remove the pedals?
    Problem Solver:
  • 17 Answers
Shifter on bolt near those arms and twist they might b a bit stiff so chuck on some wd 40 lube
Posted on Nov 15, 2009
The chain feels and sounds like it's jumping gears or slipping on the rear sprockets. It does it in all gears. It is a diamondback wildwood large 20"
The rear derailleur needs adjusting, once to establish limits (so it can't go past high gear or low gear). Everything else is up to you fine-adjusting the shifter to make the bike run quietly. If you're careless about your gear changes, you'll get MOSTLY into one gear but not quite perfectly, so the bike is always trying to start shifting into another gear - that's the sound you hear, the sensation you feel. Fine-tune your shifter positions each time you shift - you'll find a "sweet spot" where the bike runs almost perfectly silently.
No, they can't readily do that at the factory, not with chain drives. There are just too many things that can affect gear changes, and things are in a slightly different position every time you remove & replace the rear wheel, or even loosen & retighten it. Unless you're ready to spend vast dollars on a foolproof shifter system, shifting cleanly is going to be your job and your job alone. It's one measure of your bike riding skill... and the better you get at that skill, the better you feel about it.
...and your bike will like you for it.
Jul 30, 2014 | Diamondback Mens Wildwood Classic Comfort...
How do I take off factory pedals on overdrive model. Do I need special wrench.
Search the web for "how do i remove bike pedals" for vidoes. Parktool makes good pedal wrenches.
Aug 01, 2011 | Diamondback Overdrive Pro 29'er Mountain...
Got a 1999 Diamondback Wildwood bike and was trying to take off the crankshaft and front sproket. Do I need a special tool for that? What's the trick?
Hi, yes you do need a special tool. It's called a Crank Arm Remover. The tool is basically a modified puller that threads first into the inside of the crank, (after the bottom bracket bolt is removed) where it is bolted to the bottom bracket. Then, a second bolt is then threaded inward against the tapered shaft of the bottom bracket. Slowly the crank will lift away from the tapered shaft of the bottom bracket. Hope this helps.
Nov 16, 2010 | Diamondback Cycling
Looking for fenders for a Diamondback Serene Citi Classic, 17" frame and 26"wheels.
Order at your local bike shop, fenders are usually universal, not brand specific just need the right size, and they can install them too for a nominal fee. They usually are in stock.
Sep 28, 2010 | Diamondback Serene Citi Classic Women's...
I have a Diamondback bike for my wife. Wildwood model that has sticking front brakes and is hard to steer to the left. I suppose that i just have to adjust the brakes, but how do I do that?
Make sure all the break caliper support parts are tightened, and the break cable doesn't get caught on any thing when you try to turn, whenever the cable is pulled-on the breaks will be applied.
May 22, 2010 | Raleigh Diamondback Girls Della Cruz 24"
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
I have a grinding noise coming from the pedal assm. It's not the pedals themselves but the area in the frame. What's the fix and what tools do I need? It's a Diamondback Wildwood 2002.
where the two pedals meet in the middle there is a bearing and when the bearing fills with dirt it make the grinding noise you can take it out clean and grease but if it is a packed bearing you will have to get a new one
Jul 08, 2009 | Cycling
Cycling Logo
153 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
