Question about Honeywell Programmable Thermostat Heater
Three wire system, going to a five terminal thermostat? Wires from wall are red, white and blue. Terminal on new thermo is yellow ,green and then on the next row is,Rh, Rc, and w How does that work out? My old Honeywell round, gold dial type has only three wires.
  • Honeywell Master
  • 43,501 Answers
The Rc and Rh should have a jumper wire between them let it in. and hook the red wire to one of them it does not matter which one as they are jumpered. The white wire goes on the "w" terminal and the Blue wire will go on the "G" green terminal to run your fan.
This should get you up and running again!
Posted on Nov 13, 2009
    President:
  • 1,515 Answers
Here is what you need to do. You're 3 wires R= 24volts hot. White is heat or w. Blue more than likely was used for cooling Y terminal or G for fan. Lay out of a new stat is rc with a jumper wire to rh. rc =r cooling, rh = r heating. Connect your red wire to rh or rc and make sure to leave the jumper in place. Connect the white to W. On a central heat and air, you would normally have 4 terminals as rc and rh count as one.Y= yellow, but you dont have a yellow. So, if you do have cooling on this system, the blue wire will connect to the Y terminal. Green or g is used for fan. Since you have no green wire, i would know that the fan is controled through the blue terminal and will come on in heat or cool. On most heat only systems, they only have 2 wires, red and white. Same connections rc jumpered to rh, and white to w. But since you have a blue wire, I am assuming that you do have cooling also? If so, connect to Y as I said. If no cooling, leave it connected to Y anyway. I have hooked up hundreds of these heating and cooling stats, or heat only and cool only. After you connect the wiring as I have explained, and just to see what they were useing the blue wire for , either Y cooling, or fan G, turn the power back on and set you're stat to come on like you normally did with the old round honeywell.Don't get confused just follow the connections as I said and you will be fine. What I want to determine, is if you have heat only or both and you can let me know. Just connect as I said, very easy. After you turn the unit on and lets say thet the blower fan doesnt come on like it did with the old stat. Then I would know that you have heat only, and you would only have to make one change.ONLY if the fan didnt come on though. This would be the blue wire only. So, after all is connected as I said, and you start it up and the main blower fan never comes on, the only wire you need to move is blue from the Y terminal to G terminal. Try and get back to me to let me know if it is heat only one way or another.This was a long explanation, but I am a perfectionest, and want you to completly get the whole picture. I could have told you in a lot less words, but wanted you to understand in detail.Please let me know though if you are heat only. Good Luck, Sincerely,
Shastalaker7
Ps, I will be waiting to hear back, Thanks :-)
Air conditioning condensor will not run from thermostat have to go outside remve covers and jump thermostat connection . Then runs fine and cycles problem is intermitant
If it was me I would make sure the weed wacker hadnt attacked those wires as they leave the area leaving the house making their way to your condensing unit. Next, follow those wires back to your furnace control terminal area. Blower vibration can cause those little wires to break over time. Take care not to cause a break. Next, pull the thermostat off its base wall mount and jumper the red and the yellow wire, sometimes there is a blue color wire instead of yellow. If the unit outside comes on after this trick, make sure rc and rh are jumpered together on the thermostat terminal base and if they are then its your thermostat. One last thing, if someone has changed that thermostat since last cooling season, the thermostat wiring should be red to r terminal, white to w, green to g, blue or yellow to y terminal. Again rc and rh are usually jumpered. There are exceptions and at the very least see that the red wire is under the rc terminal.
Jun 03, 2012 | Bryant Heating & Cooling
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
I need the wiring diagram for this thermostat, there are four wires that are hooked up red,white,blue for yellow and green. They connect to a honeywell relay that has five connection, y,g,w,c,and r, do i...
On the fan relay hook up the red to r terminal the white to the w terminal and the green to the g terminal , now the blue needs to hook up to one of the two wires going to the outside condenser unit and the other going there goes on the c terminal . The blue does not have to go on the honeywell rrelay just wire nut it to the wire.
May 13, 2011 | Carrier TSTATHCP Programmable Thermostat...
I bought a honerwell regular digital thermostat and changed it trying to follow directions the 4 (four) wires coming out ofn wall and that were connected to old thermo were red, black, yellow and white. ...
Wiring color to Thermostat Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g. Hope this helps you. Thanks.
Jan 05, 2011 | Heating & Cooling
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
I am tying to install an RTH6400 5 in 1 thermostat but the colors of wires i have on my wall are RED, GREEN, BLUE AND BLACK, where as the book has RED , YELLOW,WHITE AND BLUE. please which do i connect to...
You need to open up the panel at your furnace(air handler) and find the terminal strip and see what your existing thermostat wires are connected to. Normally your red wire connects to the R terminal(24 volts), the yellow wire to the Y1 terminal(cooling), the white wire to the W1 terminal(heating), the green wire to the G terminal(indoor fan). You can use whatever color of wire you have existing, just make sure that the R,W1,Y1,and G wires at the furnace match the R,W1,Y1, and G terminal screws at the thermostat. Also make sure the power to the furnace(air handler) is turned off before you make any wiring connections at the thermostat or furnace.This is very important! If you don't and you short any wires to ground(especially the R wire) you will possibly ruin the system step down transformer or blow the low voltage fuse.
Nov 10, 2009 | Honeywell Electronic Programmable...
I bought new Honeywell non programmable,letters are different.
If you have a 5 wire thermostat then you have a two transformer system a cooling transformer and a heating transformer.
The cooling transformer wires to Rc - Y - G,
and the heating transformer wires to R - W the R terminal heating would be the #4 terminal from the old stat.
Aug 12, 2009 | Honeywell Electronic Programmable...
A duo therm thermostat (p/n 3105058) was removed because it would not operate the air conditioner/heater in a firan fireside camper. it was knocked loose from the wall damaging it.the thermostat is for use...
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
I'm trying to install a Honeywell RTH2310B programmable thermostat. I only have 3 wires coming out of the existing thermostat (the red wire was attached to both Rc and Rh terminals). The other wires were...
Your house might be older.  Are your receptacles two-prong, or three?
I would ignore the missing "G" wire, and connect Red to both Rc and Rh, and Y to Y, and W to W.
Jan 01, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
402 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
