Question about Canon PIXMA MP830 All-In-One InkJet Printer
Colors not printing correctly - Canon PIXMA MP830 All-In-One InkJet Printer
    President:
  • Canon Master
  • 2,022 Answers
Check your clour catriges are not dry and they are full also make sure while you giving the print command you choosing colour mode with best mode option.
Posted on Nov 13, 2009
Canon MP470 prints colors light on Mountain Lion
So go back to former driver since this one does not work. A no brainer!!!!!
Aug 28, 2017 | Canon PIXMA MP470 All-in-One Printer
Mfc 5860 red printing green - already checked print levels. all are fine.
1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
a. Press INK.
b. Press the UP OR DOWN ARROW key to select Test Print.
c. Press OK.
d. Use the UP OR DOWN ARROW key to select Print Quality.
e. Press OK.
f. Press COLOR START
The machine will generate the Print Quality Check Sheet.
2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
a. Press STOP/EXIT to return to the "Date and Time" display.
3. Evaluate the Print Quality Check Sheet.
On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
NOTE: Cyan is the light blue color and magenta is the pinkish color.
a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
4. Open the Ink Refill cover.
5. Open the cartridge covers of the colors that do not appear in the correct order.
6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
b. Press 7-6, The LCD will display CLEANING ALL
c. Press 6, the LCD will display eINIT__P ALL
d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
e. Press the BLACK START Key.
  • After the machine completes the Setup Purge it will return to the Standby Display.
8. Print another Print Quality Check Sheet
a. Press INK.
c. Press OK.
e. Press OK.
9. The machine will generate another Print Quality Check Sheet.
a. If all four colors printed correctly the issue is resolved.
b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
Scanning is not producing accurate colors for all colors. For example, Halloween shade of orange scans as pure yellow and brown comes out quite pink. Tried shutting the machine down and restarting much...
You'll need to calibrate your printer in order for the prints to come out with the correct color. In addition to this, if you're printing from .pdfs, you can set Acrobat to "print as image", this also helps in correcting the colors as they appear on your monitor, although this is NOT as accurate in correcting color as the "calibration" part.
Hope this helps. :)
Oct 06, 2010 | Canon PIXMA MP520 InkJet Printer
Printer is not printing colors correctly. Brown looks red. Is there a way to clear ink heads or ink area. case shows ink spillage, need to clean up area maybe will help with color printing.
You press the ink button and choose cleaning option and test print to see if colors are correct, clean again if colors are wrong. The spillage won't hurt print quality when it's around the cartridge area. If you are using generic inks they sometimes are not the correct color.
Feb 08, 2010 | Brother MFC-440CN InkJet Printer
I have all the correct color cartridges on my MP530 color printer. All of the sudden it coated a blue tint to my color printings. My print out look blue. Any suggestions I can correct the printer to print...
Just make sure the right colors are in the right place, photo magenta is not interchangeable regular magenta. Also run the nozzle check to make sure all colors print, if after 2 deep clean cycles you don't have all colors you may need a new printhead.
Jan 10, 2010 | Canon PIXMA® MP530 All-In-One Printer
Brother mfc 3360 model mostly problem is no printout, pls soluti
Hi!
If one or more of the ink colors are missing from pages printed by your machine (i.e. received faxes, copies and/or documents printed from the PC etc), nozzles in the print head may be clogged, or the ink cartridge in question may not be installed correctly. Verifying that the ink cartridges are installed correctly and/or cleaning the print head may resolve this problem.
To verify the ink cartridges are installed correctly follow the steps listed below:
Open the ink cartridge cover and reinstall the ink cartridge. Open each lock release lever and push it until it clicks, and then close the ink cartridge cover.
The LCD may then display:
Did you change xxxxxx? Yes No.
The LCD may display this question for the color(s) that was replaced.
Select Yes or No by pressing arrow keys or 1/2 or "+/-" key.
After all the correct selections are made, the machine will then go into a cleaning.
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will go back to standby mode automatically. Print the Print Quality Check Sheet and see if all colors are present:
Press the Ink or Ink Management key.
Use the up or down navigation key to select Test Print.
Press OK to confirm your choice.
Use the up or down navigation key to select Print Quality.
Press OK to confirm your choice. Press the Color key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, one of the three colors (CYAN, YELLOW, or MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | Brother MFC-3360C InkJet Printer
Phaser 8560 Colors are Off
Here are the directions for Tec Color correction. If this doesnt work then replacing the print head is the most likely solution. The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use. TekColor Description Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display. sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications. Euroscale: Matches Fogra glossy paper specification. Commercial: Approximates U.S. commercial press target. SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray From the workstation, select the color correction in a supported driver. Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS): NOTE: Some of the color corrections are grouped under Office Color or Press Match. 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed. 3. Click on the [TekColor] tab. 4. Select the required color correction. Apple Macintosh OS 9.x: 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [General], and then select [TekColor] from the pull-down menu. 3. Select the required color correction. Apple Macintosh OS X, (version 10.2 and higher): 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu. 3. Select the required color correction.
Jun 08, 2009 | Xerox Phaser 8560MFP Laser Printer
Wont print colors correctly
Try replacing your red cartridge as it may be dry.
Mar 27, 2009 | HP Deskjet 5440 InkJet Photo Printer
Color printing problem~only green, yellow, blue
TekColor
Description
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
