Compaq Presario 700 470024-192 Notebook Logo
Posted on Jan 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connection of cable to notebook having Windows Vista as Operating System
I have a notebook having Windows Vista as Operating System. I want to connect my Nokia handset (Model No. 6070) , I face some problems as driver CD which comes with connecting cable is not support by Windows Vista.
Will you please guide me to download the appropriate setup for that connecting cable .
Thanks
Anonymous
Level 2:
Guru:
  • Expert 134 Answers
  • Posted on Jan 08, 2008
Anonymous
Expert
Level 2:
Guru:
Answers
134
Questions
0
Helped
92081
Points
267
There are a couple of things that you can try. first change the program compatibililty mode, (for example: if you installed Nokia PC Suite). >>Right click on your shortcut icon >> select Properties >> On compatibility tab, select the match version. see pic. below.
Download newer driver from www.nokia.com.
Hope this be of some help/idea. ^_^
Cannot used wifi connection
Good day.
What is the operating system? Is it windows vista,7 or XP?
To check if you can connect wireless, please make sure that you have a wireless adapter/card properly installed on your notebook. To do this, please follow the steps below.
For Windows Vista and Windows 7
1.Click Start>Computer>System Properties>Device Manager 2.On Device Manager > look for Network Adapter and click on the arrow to the left 3.Check for any devices installed for example Atheros or Realtek 4.Please make sure that there are no yellow question marks,or punctuation marks on the device listed.
Heyy, i have just installed a fresh new installation of Windows Vista home premium x64 and i need the drivers i have checked the site and have downloaded several of the drivers and installed them, Still...
you'll find all the driver you could need here, just select the operating system from the drop-down box on the right
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1325
Windows failed to load because the kernel is missing or corrupt. On my Acer Aspire One Netbook doesn't have a disc drive. What do I need to do?
You can actually connect an external device on to your computer like an External DVD drive via a usb cable to fix the problem. Or you can also make a USB Drive bootable with an Operating System such as Windows XP, Vista or Windows 7 so that you can just insert it in your Notebook and reinstall your Operating System.
Upon startup before anything else happens (except asking me if I want to press f2 for setup) my aspire one netbook says: For Atheros PCIE Ethernet Controller... v1.0.0.5(1/22/09) check cable...
This means you should install an Operating System.
If your notebook doesn't have a dvd drive you can install the Operating System with an external drive (dvd, USB flash drive or hard drive). and press F12 when it starts to select the booting device.
Follow the link below to find out how to create a USB flash drive bootable (also works on hard drives):
http://forum.bstdownload.com/how/55-how-create-bootable-usb-stick-when-using-windows-vista-windows-7-a.html
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
I have a compaq presario cq40 312tu running windows vista but after i do a system recovery using windows partition cant activate automatic and failed
If you can't activate your operating system then try to install a fresh copy of the operating system and get it activate again. Consider also checking the internet connection of your computer if it have connection or not.
I had lenovo ideapad with windows vista home basic.right now i have installed vista ultimate,installed all drivers which come with windows vista home basic cd,but it can,t show me easy capture utility or i...
Firstly visit the website of the MANUFACTURER i.e. LENOVO and download all the drivers and any firmware available for your system and save it on your system and do keep in mind that u choose the correct version of WINDOWS OPERATING SYSTEM which is installed on the system.
Uninstall all the drivers and then clean temp and prefetch files....
Turn off your computer and then disconnect all the cables from the back of the computer.
Press and hold the computer's power button for 30 Seconds then release it.
Wait 2 minutes.
Hook up monitor, mouse, keyboard, internet connection and power cable and then restart your computer.
Install the drivers and firmwares which u have downloaded earlier. Restart your system again.
1helpful
Upgrade vista home premium
As per my knowledge, there is no version of Vista called Vista Professional like in Windows XP.
Make sure what is the version to which you want to upgrade to from Vista Home Premium to Vista Business or Vista Ultimate.
The available versions of Vista Operating Systems along with the features supported from the Link below :
http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
However, if you want to Upgrade the current version of Vista to a higher version like Vista Business or Vista Ultimate, you need to purchase Vista Anytime Upgrade kit from any retail store or directly from Microsoft.
You can find the required information related to Anytime Upgrade Kit from the link below :
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
However, make sure that you had created the Recovery Disks for your notebook using which you will be able to reinstall the preinstalled Operating Sytem along with all the Preinstalled Applications and Drivers after which you need to use the Vista Upgrade Kit to upgrade to higher version of Vista.
However, if you are currently having a 32 Bit Vista preinstalled in the Notebook, it is not possible to upgrade to a 64 Bit Vista since you can upgrade only a 32 Bit of Operating System to a higher version of 32 Bit Operating System and a 64 Bit Operating System to a higher version of 64 Bit Operating System.
Hope this helps....
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
