Question about HP TouchSmart IQ770 PC Desktop
Changed ram, now won't boot yellow led light stays on running XP
  • 490 Answers
Did you put the correct type of RAM in? and is it within the computers ram limits
Posted on Nov 13, 2009
Diagnostic lights a green, b & c orange
Rear Lights Dell Computer Error Codes
Rear LEDS are labled A through D and can change from green to yellow. Some typical LED reading might be:
A - yellow, B - yellow, C - green, D - green <-- Indicates a problem with the RAM.
A - yellow, B - green, C - yellow, D - green <-- Indicates a problem with the video card.
Refer to the Dell website for your specific model, as these lights can vary from model to model.
see more from this site
Jan 16, 2014 | Dell Precision Workstation 670 PC Desktop
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Checking power to main board
hi sir pls remove your Ram and clean it and place it back.and on the computer.if fails then change your Ram and repeat it.Ram problem can cause this issue
Dec 09, 2011 | Computers & Internet
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
Dell Inspiron N5030 refuses to boot. When it is turned on, the ON LED light stays on for a minute & goes off. There is no display on the screen. But when it is plugged to A/C, it stays on for a while...
The first thing to check for is loose ram, battery, a loose hard drive or any loose cards.
Pop the cover off the bottom, reseat the ram battery and hard drive and try booting again.
If that does not work try booting off a copy of Puppy linux on a live CD. Puppy runs only in ram and will allow you to bypass a bad hard drive to get a system running. Puppy also has system testing tools that you can check your hard drive with.
Aug 15, 2011 | Dell Inspiron N5030 Notebook PC
System unit led is yellow and start good condiotion but no signal
The light on the LCD screen stays yellow?
I would start with puling out the ram chips and see if it works,
If you get some beeps and video works with ram chips out, then its a bad ram chip.
If thats not it.. unplug all cards cd/dvd rom and harddrive to test motherboard and CPU chip. see if you can get video to work with everthing but cpu and power suppy unpuged
Apr 28, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
No boot up, display, beep, or HD action
I am having the same issue. Clearing/reset the bios will get the board to boot up, but when turned off and started again the board will not boot. you will have to clear the bios again. The board seems to be rebooting itself continuously before it evens get to the POST.
Jun 28, 2008 | EliteGroup P4M800PRO-M Motherboard
Packard Bell Imedia 1402 wont boot up
you did not install the new Hdd properly, the part of the ribbon cable with colour should be by the side of the power connector and the power connector should be connected with the red cble by the side of the colour on the ribbon cable.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Oct 03, 2007 | Computers & Internet
HP TouchSmart IQ770 PC Desktop Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
