Have a 8050 Konica. Keep getting 29-10 code. Shuts machine down. When I turn back on, it's a totally different color than before the shutdown. Running through a fiery. Copies don't have that good color anymore. Color is flat and doesn't "pop" like we're use to. Had also more problems with "blistering" on stock than normal. Have to run even light weight stock on speed 5. That's really slow. Normally we only have to use speed 5 on cardstock.
  • sam gerban
    sam gerban May 11, 2010
    this could be a number of things ,But you should preform this adjustment first, 2. Setup adjustment performed incorrectly. Recall the process adjustment standard data and perform the gamma auto adjustment after insuring that the drum cartridges and charge coronas are properly seated. To recall the process adjustment standard data, perform the following: a. Power on the copier while pressing 3 and 6 on the control panel. b. Select PROCESS ADJUSTMENT followed by RECALL STANDARD DATA. c. Select YES and then perform the normal setup. i hope this help if not you may need to call a tech
  • 1,294 Answers
Process control abnormally function.Check or change the drum potential sensor and the potential sensor board and the printer control board.Clean the drum AIDC sensor and perform process control adjustment.
Posted on Nov 15, 2009
I got code 3c00 on a konica c25 how do i reset this code its lock up
YOU GOT THE BIG ONE!!!!!! Some one tried to copy MONEY on that machine. NOW you will need to get a Konica Minolta Representative out to remove a special chip that will be sent to Konica Minolta then to the SECRET SERVICE. IN the mean time ask the Konica Minolta tech if they have a loaner, your machine is down until the SECRET SERVICE determines what has happen. SORRY the Color copiers are so good these day that they have a small chip that looks for info on currency and shut the machine down. SORRY
Oct 19, 2015 | Konica Minolta Office Equipment & Supplies
C-3725 trouble code
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. It will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
May 18, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Error message c 3725 konica minolta c 550
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Mar 08, 2011 | Konica Minolta KONICA BR BIZHUB C451...
I have problem witm color copier konica minlta 8050 with error sc28-02
Check the yellow drum charge corona to get that open the front of the machine unscrew the front section then pull out he charge corona for yellow do not have open the unit to expose belt and drum. ensure they all are seated properly
Feb 02, 2011 | Konica Office Equipment & Supplies
Error C500.
PROBABLE CAUSES:
1. Insufficient airflow during idle causing internal machine temperature to rise. Toner is backing up or solidifying in the cleaning unit box for the transfer belt causing the transfer belt drive motor (M18) to bind.
Replace the Belt Cleaning Unit (p/n 65LA R702 00) and install attached Special Printer Control firmware (version 51-PBF0 for the 8050/CF5001 and version 12-PBF0 for the bizhub PRO C500). This firmware keeps M11 (Transfer Belt Cooling Fan) ON for a period after the copy process has completed which helps keep the internal temperature at normal levels. The firmware can also be download from the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
Note: Firmware version 51-PBF0 is primarily for the 8050, but can be used for the CF5001. When using the ISW tool to download the firmware please select the 8050 from the drop down. If the CF5001 is selected the ISW tool will not see the file.
2. The paper exit fans (M61/M62/M63) DIPswitch is not turned ON.
Set software DIPSW 21-0 = 1 to enable the paper exit fans.
3. Dirty or failed transfer belt drive motor encoder disk sensor assembly.
Clean the transfer belt drive motor encoder disk and sensors. Replace the assembly (p/n 65AA -909 1E) as necessary.
4. Failed M18 transfer belt drive motor.
Replace M18 transfer belt drive motor (p/n 26WA 8001 3).
Jan 18, 2011 | Office Equipment & Supplies
Como vou resolver o erro C 3423 da Konica Minolta bizhub c253
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
Sep 06, 2010 | Office Equipment & Supplies
My HP C7180 will not print the self test diagnostic page the screen on the product says ''paper mismatch'' paper size or type is incorrect,change paper and press OK. when I do the machine shuts down then...
Your cartridges have chips on them and a date i think. So, my guess is, that the printer is alarming you that the "ink expiration is near", because soon, the chip will not allow you to print anything, so you will have to buy new ones.
The only reset method I know is used for "ink system failure" (Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate). But you need to have new cartridges for that.
Mar 08, 2010 | HP Office Equipment & Supplies
New help getting Pitney Bowes 8050 fax machine to work
The code is the same as the model number 8050, Your battery has failed and will not keep it's settings if it loses power.
May 17, 2009 | Pitney Bowes Office Equipment & Supplies
Konica 8050
need to activate jam codes on the machine so you can pinpoint the problem.it's in the 25 mode dip switch 11-7 to on
Sep 29, 2008 | Office Equipment & Supplies
Tech support
F45-20 Color registration correction
results in abnormality.
Printer control board (PRCB)
Color registration sensor /F (PS8)
Color registration sensor /R (PS9)
May 16, 2008 | Office Equipment & Supplies
128 people viewed this question
jasbo
jasbo
