Question about Samsung PCJ534RF 53" Rear Projection Television
How do i get a repair manuel
Have tv timing or snow on top of screen. how do i adjust to remove
    Problem Solver:
  • 13 Answers
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
30 in craftsman snow thrower,model no.247.883960,pulls right contionusly while operating in any gear
Howdie ther is a Pin in the shaft of the wheels look to see if it is Broken and away ya go it is easy to see
Feb 07, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
When tv warms up i get red dots in darker areas of screen
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to fix the problem.
Dec 29, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Snow on Screen
There is a bad connection inside the tuner of the set. In order to repair this, the tuner must be removed and opened. This repair should be simple for any TV repair shop and not cost much. This is simply a resolder job. It will take a few minutes to get at the part that needs to be resoldered though. Call around and get a few prices for a resolder of the tuner input "F" connector.
Dan
Aug 19, 2008 | Sony KV-27S26 27" TV
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blank Screen
Many have replaced caps on the SMPS board, with success:
2662 is a 1000μF 25v 85°C with 2663 and 2664 both 25v 100μF 25v
Another model: http://www.hotelkaveka.com/9944CU.jpg
Some other pics of different caps: http://i121.photobucket.com/albums/o229/garafrax/TV%20Repair/HPIM1458.jpg
Once you get it on, there are adjustments to the VS voltage to cure the speckle.
Jul 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
The Green Shadow...
SheriDans, I am not an expert or a TV repair person but I do have a WS-55805 like yours and am trying to repair mine. But in trying to do so I did figure out how to remove the screen. So If still want this info here it goes:
Remove the speaker cover by pulling at the left and right edges. It is held by pressure pins. You'll need a philips screwdriver to remove 7 screws. First the 4 screws that attach the cover that is between the speakers. Now follow the wires that come from beneath the center of the screen and into the TV. These wires will be attached to 2 plugs before it goes all the way into the circuit board. Disconnect these plugs. If you notice on the underside of the screen that was hidden by the speaker cover are 3 screws that hold the screen in place. Remove the screws. To remove the screen you'll have put your chest against the top of the screen and put your hands at the bottom of the screen, right hand at 5 o'clock left hand at 7 o'clock, more or less and push up gently. This will release the screen from the clips that is holding it in place at the top. Now you can grab the screen from the sides and remove it completely.
To replace the screen remember to position it an inch or two above the top of the TV and let drop slowly.
Hope this helps.
Apr 07, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Ts-4557
easy way to adjust the convergence is, first off blue back option. Then check snow on the picture., if each snow carries any color on side. adjust convergence till color disappears. take long time but it is very easy no need other equipments
Feb 08, 2008 | Mitsubishi TS-4557 45" TV
My rca d61130 projection tv has red/pink faint lines
It sounds as thought he convergance needs to be adjusted. You will need to push the auto adjust button or go into the menu and do a manuel adjust. Any adjusting instructions should be listed in your Operator Manuel. If you require more assistance in this matter, please write back. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | RCA D61W20 61" Rear Projection Television
White speckly 'snow' on screen
y sustain board needs adjusting or replacing
Oct 10, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Samsung PCJ534RF 53" Rear Projection Television Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
