Question about Panasonic Televison & Video
Does th42pxb panasonic have an optical connection
How do I connect a sound bar to my Panasonic TX-50A300B I want to use an optical cable as ear phone jack does not produce a decent level
If your TV has an optical port on the back, you simply get an optical cable long enough to connect the two. On your TV sound setup screen you'll have to select optical out so the sound from the TV will be switched from the RCA jacks to the optical out port.
Nov 21, 2015 | Panasonic Televison & Video
How do I connect a Panasonic TX-50A300B (TV) to a Panasonic SC-HTB20 Home Audio System?
The audio system sports both a HDMI input AND an Optical input - one can use either. The TV has both of those as outputs so you truly can use either!
You'll need a HDMI to HDMI cable or an Optical to optical TOSlink cable.
Feb 16, 2015 | Panasonic Audio Players & Recorders
How do I get digital audio out from a panasonic panel to optical in on a yamaha amp
The TC-L55E50 has an optical output located on the rear of the TV. Simply connect the optical cable from the TV to the amplifier.
Mar 23, 2014 | Panasonic 55 inch VIERA 1080p 120hz LED TV...
My home theater doesnt have optical connection
IT WOULD BE MORE SIMPL TO CONNECT AN AMPLIFIER WITH FIBER OPTIC INPUTS
Apr 11, 2010 | Panasonic PT-52LCX65 44" HDTV
No sound from TV to home theatre system
hdmi does sound to,,,try if the reciever has hdmi,,unhook the optical cable and try it by itself,,and vise versa
May 17, 2009 | Panasonic AG-VP320 DVD Player/VCR
Panasonic SA-HE9 amp / Sky+ optical
i Have a Panasonic SA-HE9 and i cant get the optical cable too work on my Playstation 3 to get sound from there. can any 1 help me with this?????
Feb 19, 2009 | Panasonic SA-HE90 Receiver
Need to connect xbox 360 to panasonic sa-mt1
If you want to play 5.1 sound, and you got to need this fiber optic cable(black single cable)..with reciver decoder with optical on IN, to connect the xbox 360 machine on, and the high defintion cable of the xbox.
Feb 19, 2009 | Panasonic Home Theater System System
Connection problems
Yes you can by connecting a optical cable from bd35 to your systems optical in put,then select this in put on your sysyem and set sound to prologic2, you will not get HD MASTER or DOLBY TRUE HD audio but will get dolby digital and dts.
Hope this helps.
CABLE GUY.
Jan 05, 2009 | Panasonic SC-HT520 System
I have a Panasonic TH-42PZ700A High Def TV and a Panasonic 160gig DVD Recorder. They both have 1 optical audio output each. I have an Onkyo amp which has 1 optical input for audio. How can I have 5.1 dolby...
Dear ritchiewayne,
Please connect optical out of the DVD recorder to the input of panasonic TV. Next connect TV's optical out to the input of Onkyo amplifier. connect speakers to the out put of Onkyo amplifier.
ramesh22
Jun 15, 2008 | Panasonic Televison & Video
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
