Question about Maytag Legacy Series Top Load Washer
I have a Maytag wash machine where the main seal just went out again for the second time in (3) years. This is getting too expensive to keep fixing. Should I get a new one?
  • 155 Answers
If you seal keeps failing maybe the shaft is pitted and worn causing it to wear prematurely as far as buying a new machine you will have to make that decision if you do fix again check shaft you may be able to restore it with some emery cloth hope this has helped
Posted on Nov 13, 2009
Washer started banging and smoking
Make certain that these items are not covered within your warranty before venturing into actual repair or a new purchase. If out of warranty, this can be an expensive endeavor (e.g.: typically $300 or more total)
Apr 13, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Jul 02, 2009 | Maytag PAV2300 Top Load Washer
Seals keep ripping out on the washer, which causes other probs
info from a bosch tech. alot of times the boot gasket gets ripped from clothes not put in machine fully. and also the basic take things out of pocket. I remember fixing a washer and the customer sworn up and down that she didnt have anything in her pockets she check every wash the whole nine. so after i manually drained the unit guess what i so. 3bobbi pins and 2 pennies. so just be very careful with what you load. sometimes clothes get stuck between the gasket and the tube,
Apr 19, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag fav6800aww wont spin
I have a 3 year old neptune top load and have experienced the same problems you all have had here. Problem: Washer was leaking 1/2 gallon of water every load and sounded like a freight train on spin cycle. I usually do my own repairs but didn't have time so I called A&E by the recommendation of Maytag. Diagnosis! The tech said the tob o-ring seal was bad as well as the transmission. I had no reason to dought this professional right. I did after he told me the price... $450 to fix it!!!! I reluctantly gave him his $65 service call fee and said goodbye..
I called maytag and they said the transmission should have been covered by warranty (10 years). The tech was either an idiot or just plain trying to rip me off. I called Maytag back and they sent me the supposed bad tranmission and seals. I replaced them in 1/2 an hour. Guess what.... This did not fix the leaking or the loud spin cycle noise. What is the problem with this neptune model? The problem for every owner including myself has at minimum been the main seal inside the outer tub. This leaking for months took out the bearings causing the noisy spin cycle. I replaced both 6207-2rs bearings compliments of ebay for $6ea. After reassembly it was like new for the first load. On the second load it would stop on the spin cycle.... It would cycle between the agitators and trying to spin but never engaging into spin. After 5-6 minutes it gave me the code that stated an unbalanced load. What the problem was is the leaking had made its way into the clutch as well. I pulled the clutch/pulley back of and cleaned and lubed it. Problem solved! She now goes into spin and has no problems whatsoever. I'll never call A&E again...Mechanically this washer is a piece of cake to work on. Electronically it could be a bear... The bearing replacement took approx. 2 hours total from start to finish. Next time I'm buying Kenmore and the extended warranty. I'm tired of screwing with this junk... Good luck guys.... Jos Roach... CA.
Dec 04, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Transmission Dead, Rusty Water, Broken Seal and Loud Noises
This has the notorious triple lip seal. This will happen again and again. Do yourself a favor and get a different machine. Labor will be from 1 hour for just the seal, to 2 hours if transmission too.
Nov 16, 2007 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
