Question about Whirlpool Duet GHW9150P Front Load Washer
Washer is in rinse cycle but stopped working. full of wet clothes and water in tub. don't know what to do
    Problem Solver:
  • 11 Answers
Sounds like the lint catch basket, located with the drain pump is clogged with lint, debris or even socks. (I found 4 pairs in one once) Its located at the bottom right side. Look for a twist cap lid. Before unscrewing it, I suggest you pull the unit away from the wall and tip it back at almost 45 degrees, this will keep most of the water from shooting out at you and your floor when the cap is removed. The basket is attached to the cap.
Posted on Nov 13, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
After final rinse and spin cycle clothes are still wet
I can't solve this but am having a similar problem. There is no water in the tub but the spin cycle does not get enough water out of the clothes and they're very wet. This causes the towels especially... to smell really bad. The tub is very loose. How can this be fixed.
Jul 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
IE code & water still in clothes & tub after removing
hi the "ie" code is no water inlet which would be a inlet water valve,try replacing then try that hope that helps.
Dec 13, 2008 | Washing Machines
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Rinse Cycle
Is this a fairly new Energy star machine? If it is the rinse cycle is a spin only cycle with several spray rinses.
You may have an option switch that gives you a Fabric softener option, use this option and you will have a deep tub cold water rinse.
Make sure you are using He detergent.
If you have soft water use less detergent
Let me know if you have further questions.
Your sales rep should have told you this!
May 04, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
