Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
I have a kenmore gas oven and cannot find the model number. The problem I have is there is no gas coming to the oven. Gas is working on the range top. When turning on the oven nothing is happening. The wiring appears to be intact. No gas and no ignitor.
  • 236 Answers
If the ignitor is dammaged(slight Break) it will not glow and not allow ignition. The glow bar ignitor has probably got dammaged. Have you moved the stove ?
Posted on Nov 13, 2009
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
I have a kenmore gas oven/range model 362.752.6190. The oven will not ignite but the range burners work great. I assume that means its the ignition system on the oven. Do you know where I can get a new...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 01, 2010 | Kenmore Ovens
Ignitor for oven comes on but gas release cuilds up before oven ignites causing a voom
I have a Kenmore Gas Range, model 72503. #1 problem-the orficies were not installed properly; #2 problem-when I turn the top burners on, gas comes out before the ignitor comes on. I called Sears, they sent someone who said that the burners can't be adjusted. I feel this is very dangerous. This is a new 2011 model, made for Sears by Frigidaire. Who should I contact about this problem. Sears say it is out of their hands. Help!
Sep 12, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
On my gas kenmore oven, the oven first wouldn't get up to temperature, and now 3 months later it just doesn't heat at all. There is no gas smell or indication that there is a pilot light. My gas broiler...
Replace the glowbar ignitor in the oven. Turn off the gas supply. Remove the oven racks. Remove the base pan in the oven to access the ignitor. Most plug in. Some have wire nuts.
Your local appliance parts store will need the model number or the ignitor for a correct replacement.
Oct 31, 2009 | Kenmore Ovens
Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Gas Range
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
Jul 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
184 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
