Hi there, I am using Siemens speedstream 4100, and every fifteen minutes or so, my LAN connection drops all of the sudden.
During this time period, if I go to command prompt and try to release and renew my IP, it gives me the following message "An error occured while renewing interface local area connection: unable to contact your DHCP server. Request has timed out."
The only way I'm able to get the connection back is if I turn off speedstream and turn it back on.
Does anyone know what might be causing this problem? I would appreciate any assistance you could give me, thank you!
-   I am having the same problem. The internet goes out for 1-2 min every morning around the same time. It will do this several times a day at all hours. I lose connection then it restores. Some days this will happen 10+ times. AT&T said it was me and my line is fine. I think they are full of BS. Why does it always happen around the same time, and what would start this problem. I have had no problrm for last year and a half. I am going to try firmware but I feel it is there end. And how do I collect losses from AT&T for this problem. It has cost me 1 job and dozens of work hours.-   beachpartybo
Feb 25, 2008
-   The 4100 B I have also loses connection and has to be turned off and on to reconnect. I have a D-link DI-524 router which I have updated the firmware on. I running windows XP and 2000 the home network, could the two operating system be causing the problem?-   Fire Eagle
Solution #1
posted on Jan 08, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Please check with the Internet provider,there is an bug occouring with the exchange server.
Try to put another modem, if you are having the same problem,then it is the your service provider problem.
If no problem try to check the software setting with the first modem.
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to...
(More)
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to the laptop, now, the internet light will not come on. If I directly plug the modem to the laptop, all four lights are lit. When I plug in the router only three lights are lit. I have tried everything.
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light...
(More)
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light just continues to blink
no internet light..every thing else working..i reset...unplugged and plugged up every thing the...
(More)
no internet light..every thing else working..i reset...unplugged and plugged up every thing the right way....im thinkin its somthing to do with at&t
internet explorer flashed turning off your comp.to install new up dates when finished no service...
(More)
internet explorer flashed turning off your comp.to install new up dates when finished no service flashed, lights not working on modem are ethernet, internet and aactivity
