Question about Samsung SCH-a870 Cellular Phone
When you plug ur phone 2 the pute, does it give u simple instructions 2 transfer pictures from phone 2 pute
How do I transfer pictures from my phone to my new phone?
therez bluetooth or transfer 2 ur computer den 2 ur new phone
Jul 11, 2010 | LG VX8300 Cellular Phone
2002 chevy duramax fuel gauge stopped working and makes vibrating noise sometimes around back fuel tank is this a simple fix and how thanks
Well I have a 2002. I have had this prob from the day I drove it home from the dealer. Evry time I'd put fule in the rear tank the guage stopped working. The transfer pump stopped working. It was back at chevy (3) times, and still no fix. They keep puting in new rear transfer pumps in it but that is not doing it.
It is an Electrical Problem, I keep geting rear transfer pump codes. So I was just unhooking the bat's but it's a pain.
So I just stopped puting fuel in the rear tank. And now if it stops working I just us the scanner to clear the codes and it will start to work... I am so done with this truck.
This truck also had ( whater pump, (2) Glow plugs, Injectors, fan cluch,) all go out in the first (5) years. GM, Is trash...
Jan 18, 2010 | 2002 Chevrolet Silverado
What is the procedure to transfer files from comp to my LG phone through USB
first you will need the usb and mini usb plug. plug the usb end into your computer, then plug the mini usb into ur phone . it will pop up on your computer as found new hardware then windows will proceed to install it . then u can go to your pictures and right click the picture u wish to transfer. click send to wat ever drive ur phone will be using. or you can open the drive that the phone is on and copy past.or drag and drop. either way will work. if you have a memory card in your phone u can plug insert that into the card reader on ur computer. and copy past or drag & drop
Nov 11, 2009 | LG Vu CU920 Cellular Phone
How do I transfer pictures and videos from my LG VU Mobile phone to my PC, and vice versa?
its easier to get a micro sandisk card & put into ur phone & easily transfer files back and forth from ur phone to ur computer. thats what i do & its very simple.
Sep 24, 2009 | LG Vu CU920 Cellular Phone
How do i get pictures off my samsung phone
Hiii
can u be specific what cell phone model ur using?
If it supports a USB connection, then samsung usually detects as a memory storage device on pc when its connected with USB cable, u can simple browse to the file and copy it to ur hard disk.
or
Download samsung pc suite from samsung website and follow the instructions while installing it.
or
if u hav a bluetooth enabled handset and have a laptop u can transfer files using bluetooth, or on desktop use a usb dongle to share files between ur phone and pc.
regards.
hope it solves ur query
Sep 07, 2009 | Samsung Cell Phones
How do I download the pictures from my phone on to my computer?
You could do this in several ways, but here are the most common:
1. If your computer has a bluetooth device, you could pair your phone with your computer and transfer the pictures
2. If your phone came with a USB cable, connect your USB cable to your phone and plug into a USB slot on your computer and transfer your pictures.
Regards.
Aug 30, 2009 | Cell Phones
Blinkin Icon
If ur aim is to transfer pics from camera to pc then may be u should give mass storage option a try, simple and requires no cd.....in xp ur camera memory will be automatically detected.But for this the mass storage option should be selected in d camera. you'll find it here
In Menu=>Setup=>Interface=>USB, select mass storage.
connect to ur pc and ur done.
Hope it helps......good luck.
Feb 01, 2009 | Nikon COOLPIX S10 Digital Camera
V3r motorola free download
hi rhonda,
             just turn on the bluetooth in ur laptop and in ur mobile...select the picture you want to send..go to options and click send via bluetooth...ur phone now searches the connected bluetooth devices around it..once it detects ur laptop, select it and give send....in dis way u can transfer data( pictures, files, videos) from mobile to laptop....
good luck
Jul 04, 2008 | Motorola Mobility RAZR V3
Not there?
try download pc suit from motorola site and then ur pc will show icons for transfring ur videos and songs 2 ur hand set, reply me
May 23, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Phone Transfer
drussilla,
u hve many options..
1. use ur bluetooth to transfer files from ur fon to ur computer if ur computer has a bluetooth..
2.if ur fon has a memory card,insert it 2d card reader of ur computer so that u can transfer ur files from ur fon 2 ur pc
3.simply use the cable,usb cable that connects ur pc and fon BUT u nid 2 install the driver first so that ur fun can be recognized ny ur pc..
Apr 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Samsung SCH-a870 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
